LUA script for Sonos
Hitman_85
Hello everybody,
I climbed from HC 2 to HC 3. Actually I thought it would be possible to trace all the scenes. Unfortunately, Fibaro has adapted the LUA Editor. Since then I have tried unsuccessfully to put the IFTTT webhook trigger that I had set up for Sonso back on the Fibaro keyfob. Can anyone help me what exactly I have to enter for a LUA code on the "Action" page ????
Hitman_85
Edited by Hitman_85
fehler
3 hours ago, Hitman_85 said:
No, the scene is on manual. Would this be wrong?
On manual the scene doesn't triggered....
I also just tried it on automatic. With the X on the keyfob, the music starts again at the beginning of the playlist, although it should actually stop.
is X button on key-fob is key=4? If so according to your scene it should start play.
Currently sourceTrigger not supported, so you need to create scene for every action (like pause, forward etc..), or to wait for next release (recommended)
Edited by cag014
  • No, the X key is on the 3rd, which is what I specified in the scene. A control also works, but the music is not stopped.
    In scene "Actions" you're sending play command, so it should start to play.
    To pause/stop the music please replace
    fibaro.call(50,"play")
    by
    fibaro.call(50,"pause") or fibaro.call(50,"stop")
    Edited by cag014
  • I've already done that. When I play the scene there it works without problems. Just don't stop with the keyfob.
    /monthly_2020_02/808189086_2020-02-2411_46_09-Window.jpg.3c5a2e0a91c42672c538cba2b7911b59.jpg" />
    Did you set the scene to "Auto" ?
    yes, I did....
    Maybe you will be interested in this:
