  • 2
Aeotec multisensor 6 not working
Willem
After adding Aeotec multisensor 6 to the HC3 the HC3 recognizes the Aetec MS6. The MS6 does not send any values. All remains at 0. HC3 does come up with a template for the parameters however changing the parameters is impossible, they remain at 0.
Thanks,
Willem Bousema
Switching from HC2 to HC3
Edited by Willem
typo
11 answers to this question
Thanks,
Willem Bousema
did you include secured or not secured?
don't know if you have that choice in hc3
Try the otherone and include close to hc3
Edited by akatar
Hi @akatar,
the include options are the same as on HC2 :-D
@Bodyart
aah thanks,
i don't own a hc2 anymore and i am not going to buy a hc3, even the simply questions i don't get an answer.
  • 20 minutes ago, Bodyart said:
    Hi @akatar,
     I included secured. On the above suggestion I excluded then included non-secured. That fixed the problem!!!
    Thanks!
    Willem
    You can set parameters w/o template.
    I had several issues with moving over my Aeotec Multisensor 6 från my HC2 to my HC2. It took multiple removals/inclusions before it worked. I think my HC2 did remove it - but not completely. I think I added my with all options, (Device is located far from the HC, NWI and security mode). It works now in the HC3.
     i have also the problem wit include this device in HC3!
    It is only applicable to include it as non secure device (poor)
    What i have also identified, the template is not fully implemented with all options.. since version 1.11 of this sensor it is an option for configure the led on/off (option 51)
    HC3/Aeotec MS6 (USB Powered, not in security mode) - I'm unable to configure an Association with a Fibaro Dimmer 2 module, there aren't any light options there in the dropdown from the motion sensors Associations screen. Any ideas, am i doing something wrong maybe?
    When i included MS6 and the distance was not close enough to HC3, the lifeline group1 could not be created and no association to other devices is possible. I did software recovery or recover until i got lifline. Some device i must exclude and include again. Only one MS6
    i must reflash to get working.
    I got latest 1.13 firmware on MS6. You should now that template is for earlier version of MS6.
    No problem to config with parameters.
