Setting the thermostat temperature above 30 ° C in the HC2 interface
Demin_KA
How can I set the temperature on a Qubino On / Off thermostat above 30 ° C in the Fibaro HC2 interface? I want to control the temperature of the water in the indirect heating boiler and turn on the thermostat at 50 °C.
Edited by Demin_KA
3 answers to this question
Can you describe a little more clearly why you can not set it higher than 30 degrees.
I use mine up to 45 degrees and the sensor can handle up to 125 degrees.
  • The HC2 interface itself does not allow you to select a temperature greater than 30 °.
