SmartHomeEddy 884
This Quickapp retrieves energy consumption, energy production, gas and water usage from the (P1 Monitor) energy, gas and water meter.
This Quickapp uses the software of ztatz.nl to get the values from your smart energymeter.
The ztatz plug-and-play software can run on a Raspberry Pi or in a Docker container.
The Energy consumption and energy production are added to the HC3 energy panel.
Use the child devices Todays Consumption and Todays Production to store energy data (kWh) in the Energy Panel.
And use the child devices Consumption and Production for instantaneous power (Watt) in the Energy Panel calculations.
Child Devices for:
/monthly_2021_08/P1-monitor-1.png.98df79a87caffc2b6a1bc8e44bc86bf1.png" />Please login or register to see this attachment.
Interval:
It is possible to process messages from the smart meter every second. Of course, this is only possible if the smart meter actually sends a message every second. This can be turned on via the ztatz software P1 port configuration page via the "maximum processing speed" option. Note that this gives a higher load on the Rpi (or Docker). It has been tested on the Rpi3/Rpi4 and works well on it. Older or other RPIs have not been tested.
The P1 Monitor QuickApp uses 2 API calls each cycle, and if you also use Waterflow, 3 API calls each cycle. With an interval setting of 10 seconds there is an API call every 5 seconds (and with Waterflow enabled, every 3.33 seconds). So the fastest interval setting will probably be 3 seconds with Waterflow and 2 seconds without Waterflow.
Ztatz software:
Docker container based on the ztatz.nl software: The container version has the same functionality as the full version for the Raspberry Pi. Docker container:
I use a Raspberry Pi Smart Meter Cable Starter Kit
Version 2.0 (8th January 2023)
Version 1.6 (8th January 2022)
Version 1.5 (4th September 2021)
Version 1.4 (11th April 2021)
Version 1.3 (13th February 2021)
Version 1.2 (6th February 2021)
Version 1.1 (18th January 2021)
Version 1.0 (15th Januari 2021)
Version 0.3 (16th August 2020)
Tested on
QuickApp variables (mandatory, they will be automatically added with the default values):
Download the QuickApp here (download the file and un-zip):
or Fibaro Marketplace:
How to install:
16
6
4
Mar 13
9
Feb 20
9
Feb 6
7
Mar 31
6
SmartHomeEddy 63 posts
JLT007 16 posts
claudent 6 posts
marcelo pires 4 posts
Mar 13 2023
Feb 20 2022
Feb 6 2021
Mar 31 2021
SmartHomeEddy
This Quickapp retrieves energy consumption, energy production, gas and water usage from the (P1 Monitor) energy, gas and water meter. This Quickapp uses the software of ztatz.nl to get the values f
SmartHomeEddy
I do now, so soon to come: Water Flow Device ? Please login or register to see this attachment.
m.roszak
We will check it out, thanks for the report.
108 answers to this question
