Siri shortcuts problem
JsonFib
With this update Siri Shortcuts no longer works. Trying to run one fails with message that there was a problem with the app.
Opening app and running scene manually works.
  • Yeah really strange. Previous release worked flawlessly. Have restarted app etc but no change. Have not restarted phone though. Might try some more stuff tomorrow.
    @JsonFib update 1.7.0 uses a new mechanism to manage Siri shortcuts which differs from one used in the previous updates. Apart from restarting your phone we would recommend removing your current shortcuts and creating new ones for scenes that you want to run. Please let me know if it helps.
  • Thanks you for the information!
    I will do as you suggest, but most likely it won’t be before tomorrow evening at the earliest.
    Will report my findings!
  • Success!
    Deleted all shortcuts, restarted iPhones and iPads, then re-created the shortcuts.
    Now it all works great again.
    Thanks for the help!
    • 1 month later...
    4 hours ago, PawRew said:
    Same problem here, but I could not see Home Center app in Shortcuts ios 13.4.1
    Try reinstalling the app. Worked for me.
    • 1 month later...
    • 5 months later...
    W dniu 9.06.2020 o 13:54, interested napisał:
    I could not see Home Center app in Shortcuts ios 13.5.0 and 13.5.1
    Me too. Fibaro, aby idea?
    • 2 months later...
    • 11 months later...
    Some scenes are visible some not. Only the very old scenes are appearing in dropdown of scenes in Shortcuts.
    Tried reinstalling, but no help. Any news on this?
