I updated fibaroapiHC3.lua to v.105 with support for the new QA file format.   If you use the hc3_emulator.deploy=true feature to deploy the real QA you are working on to the HC3, there is some new benefits. Default is that the code will be included in the QA file "main" if you deploy on the HC3.   In your code you can include other files with Please login or register to see this code. If you run in ZBS this will be just a Please login or register to see this code. which mea
    1
