SDK for remote and offline HC3 development
jgab
  • 10 minutes ago, petrkl12 said:
    OK, now I understand
    I need "only" test of pressing buttons and start correct function in ZBS for debuging
    btw. in HC2 you created http page with some buttons in ZBS and it could be also possibility how to emulate press buttons
    Ok, it's been on my todo list to make a fake web UI for QAs - I will have a look at it.
  • New version v 0.100
    - New format for credentials file.
     A file "credentials.lua" will be loaded at startup and the table return assigned to hc3_emulator.credentials
    Ex. a file that looks like
    will set hc3_emulator.credentials = { ip = "192.168.1.66", user = "admin",  pwd = "admin" }
    ...which are the necessary credentials to connect to the HC3.
    You can also add other credentials to the table that you need to access other services. To set quickVars to the values do
    this will initialise  the quickVar "HueIP" to hc3_emulator.credentials.HueIP when running QA.
    - Web UI support. When running a QA, open http://127.0.0.1:6872/web/main (If you have the fibaroapiHC3plugin you have the short cut option-cmd-e to open browser)
      UI needs to be defined in header.  Ex.
    If you also have a proxy on the HC3 the sliders will be synched...
    Here is a little demo
    ...and no, I don't think I can emulate UIs for childDevices as they use custom js controllers.
    Hello.
    I am very grateful for your great work (sdk)
    I have problem with new version 0.100.
    /monthly_2020_07/K-20200717-001071.png.81563af9d68d343e93a429f599304031.png" />
    and...with version 0.99
    It starts when typing   hc3_emulator.start{}    eof.
    if not type "hc3_emulator.start{}", it does not start.
    I call fibaroapiHC3 with this code.
    Can you help me?
  • 12 minutes ago, rangee said:
    Hello.
    Can you help me?
    Yes, since .99 the way to include the emulator changed.
    You should do
    ...no .start() at the end (everything moved to to header) and add "not hc3_emulator" to the initial condition.
    and more that the credentials.lua format changed. See
    @jgab Okay. THX   :)
    It works but .. something wrong.
    Then error occurs. lien fibaroapiHC3.lua's  line 112x and error below.
    So I changed...
    with code,  my code init successfully.
    Did you unabled api.call(/refreshStates) ?? then why?
    Can you roll-back it or give options to use or not
    Edited by rangee
  • 2 hours ago, rangee said:
    @jgab Okay. THX   :)
    Where does _QVAR come from? You include it yourselves? But if _QVAR is like in your example nothing wrong so far....
    Quote
    So this doesn't make sense. It seems like you call self:setVariable with number 4 as the first argument. Where did that come from?
    The only way I can repeat that is if I add a '4' key to the _QVAR struct, like
    Quote
    So I changed...
    No, no, no, this will break the code if you do self:setVariable("myVar",{a=9}) which is allowed. The value to setVariable can be anything.
    The bug you need to hunt down is why a number has sneaked into being a key in your quickVars.
    Quote
    api.get("/refreshStates?....") is supported when you set hc3_emulator.poll=<ms to poll>.
    What kind of problems do you have? How do you use it?
    P.S. I see that the line numbering doesn't match in fibaroapiHC3.lua. Have you added/removed code in the file? If so what code and why? There should be no reason to modify the file and if so let's make it a configurable option...
  • 17 minutes ago, petrkl12 said:
    @jgab
    In new version - is there possible to create web UI directly from existing QA?
    No, it must be declared in the code headers as hc3_emulator.UI = ....
    ...and on the HC3 it must be a proxy QA - that's the only way I can get the UI interaction on the HC3 back to ZBS (and the web GUI)
    However, I will provide a function to read the UI of an existing QA and print it out as an "UI" table, so it can be pasted into the code, it that is of any help.
    @jgab
    Oh. I change <function rawCall(method,call,data,cType,hs,to)> to connect hc3 at outside from my home.
    (Because.. I use https to connect at outside)
    I set a boolean value   "hc3_emulator.credentials.https" and add lines...
    Anyway.. I'll explain with you orginal fibaroapiHC3.lua  sdk file.
    This is  my init setting and _QVAR and  line 1126's code(self:setVariable  with function Quickapp:__init(Device))
     This is original code from yours.. and this occurs error.
    So I tried to find out what's wrong.
    There's something strance key  3B, 60, 2C, 48, 0E, 36, 44
    I didn't add that. Where they came from?
    Need more information..
     and finaly...
    /monthly_2020_07/K-20200717-630631.png.47e6704b299c304c4878ffb7ea110ae7.png" />
    what?   What's going on?
    I just  set   hc3_emulator.quickVars = _QVAR or {}   and _QVAR has no problem.
  • 40 minutes ago, rangee said:
    @jgab
    Ok, I'll add a flag for https in the next version. I think it's better to call https.request than hope that http.request will deal with it. (It may change in the future)
    You declare _QVAR before "if dofile" ? ok.
    I assume the loop should be
    ... but it doesn't change anything.
    Well, setVariable will always asserts that the first arg should be a string otherwise it will throw an error.
    Somehow, someone corrupts your quickVars table. ...and I don't think it's me. But let's continue to look.
    When you have a number key - can you print out the json representation av the value? It seems to be a table,  maybe we can recognise the values in the table?
    Can you also give me the whole initial ZBS log when you run the code until it crash?
  • @rangee I have uploaded v 0.101 on my gitHub with some extra checks. Try it and let me know.
    Oh, and hc3_emulator.apiHTTPS=true will use https for api calls.    Ok, now it's fixed. just pushed a new version (still v 0.101 though)
    v 0.101  works with no error.
    And here's error when run with v 0.100
    I use api.get("/refreshStates" ..)  in some of my QA to trigger the device like your ER4.
    some QA(A) not uses api.get("/ref...")  some QA(B) uses.
    Before v 0.98.. it was not problem.
    But after v 0.100,  I need to change   hc3_emulator.poll=ms  when I test QA(B) and hc3_emulator.poll=nil when I test QA(A).
    I do not need polling when I work with QA(A)
    But.. if you need to do it this way..  remain it.  I will adapt it.
    I found _debugFlags and  set _debugFlags.trigger = false...  no more trigger message.
    Good that it solved itself.
    Yes, fibaroapiHC3 will poll and store events/triggers in an internal queue (polling every ms given in  hc3_emulator.poll).
    All user calls to api.get("/refreshStates...) will get events/triggers from that queue.
    If hc3_emulator.poll=nil it will not add triggers to the internal queue and you will not receive any triggers with api.get("/refreshStates...).  However, if you run in offline mode (hc3_emulator.offline=true) calling simulated devices will push triggers to that queue....
    So there is no way to get /refreshStates without going through the fibaroapiHC3 internal queue now.
    The reason is that the emulator wants to call the HC3's /refreshStates to get current states and if user code also do it it will put too much load on the HC3. Instead user code will get /refreshStates values from the values the the emulator has fetched. It also makes it easier handle "offline" mode to have an internal queue...
    If you don't need polling set hc3_emulator.poll=false
    Yes, hc3_emulator._debugFlags have some flags that turn on/off various debugging messages.
  • Workflow with fibaroapiHC3
    I thought I'm going to share my workflow when I develop QuickApps these days.
    1. Make sure that you have downloaded the latest fibaroapiHC3plugin.lua from my GitHub and installed it. It gives, besides tooltips and completion for fibaro api commands, also keyboard shortcuts for some practical things.
    2. Make sure that you have a credentials.lua file with the HC3 credentials
    3. Open new empty window in ZBS and choose Edit-HC3 SDK templates...->QuickApp
      This will insert skeleton code in the buffer for a QuickApp with the right headers to include the emulator etc.
    4. Edit hc3_emulator properties, names etc.
    5. Add hc3_emulator.UI table for buttons sliders etc.
    6. No hc3_emulator.proxy yet...
    7. Add code. In your code you can do a  'require("<Lua file>")' to include a file with common functions that you often use in your QuickApps. It should be the filename without .lua. It's best if the file resides in the working directory.
    8. Run
    9. Open the web QA interface with View->HC3 Emulator (shortcut option-cmd-E)
      Check that buttons sliders labels works
    10. If everything looks ok. add  hc3_emulator.proxy=true
    11. Run again
    12. Check that the proxy app on the HC3 works with UI interaction etc. Look at the HC3 log for the QA to see if there is something the emulator missed.
    13. Everything works?
    14. add hc3_emulator.deploy=true
    15. Run
    16. The emulator will create a QuickApp with the real code on the HC3. It will substitute any 'require' in the code with the required file's code, because the HC3 doesn't support 'require'
    17. Voila, you have developed and debugged your QuickApp offline and then deployed the working version to the HC3.
    (video may come...)
    On 4/18/2020 at 10:51 AM, jgab said:
    You need to have installed
     so that require("mqtt") works from fibaroapiHC3.lua
    Would it be possible for you to add a quick post showing how to install luamqtt ? I am running ZeroBrane on Windows 10.    Sorry - I tried but got in a mess...
    Update
    I've played some more and it's a lot of work it seems just to add the mqtt library - I have memory errors being thrown from luarock during the install of luasocket and apparently that's a 64 bit vs 32 bit issue so I'm going to give up on the mqtt library install and just use your great sdk for other things.  The installed luasocket version was too old to satisfy the dependency.
    If anyone has a step by step or easy install I'll give it a go but for now I'll debug mqtt directly on HC3.
    Edited by xAPPO
    more info
    Update
    Unfortunately, Windows and I parted ways many years ago...
    Do you run the latest version of ZBS? I think that there were some updates of the Luasocket version, but maybe that's what causes the issue. ZBS has it's own version of luasocket that's come with the installation (and own versions of Lua) so you shouldn't need to install it
    The
     is an ancient article (2013) and everything (Lua, luasocket) comes with the ZBS installation these days (parts are written in Lua).
      is a pure lua library so I pulled it down as a directory named 'mqtt' in my ZBS working directory. require("mqtt") will look in wd.
    But I'm all MacOS.
    @10der, have you tried fibaroapiHC3 with MQTT with VS? Need to install
     so that require("mqtt") works.
    Anyway, I have only played a little with the MQTT functionality so I'm not sure I have got all the messages right (the way they do it on the HC3). So, if someone does something serious with fibaroapiHC3 and MQTT it would be great as we could iron out the differences...
    Done. Installed.
    trying to understand what is next ;)
    Jan can you give a example what I should test.
    thank you
  • 1 hour ago, 10der said:
    Done. Installed.
    thank you
    Well, I manage to run code like this
    @jgab updated module now req lfs what not installed in my env
    well.  i have fixed. copy from ZBS.
    continue testing
