Netatmo Presence
wojciechS
8 answers to this question
On 3/9/2020 at 8:01 AM, boomx said:
You can use the stream of the cam... see screenshot :)
Wow ! Interestin.
Can I ask you which settings you used to get this result ?
34 minutes ago, pnutp0wer said:
You can check this tutorial:
Yes... it is the same on the HC3... :)
On 10/2/2020 at 8:37 PM, Guest winiu said:
I bought a virtual, what to write in the code variable.
Did you get an answer?
  • -1
