Google home integration stopped working on HC2
gandhy77
Hi all!
My Google home  integration stopped working after II think) the last update of HC2. In the Google Home app the Fibaro Devices in the rooms are listed but unavailable. Relinking the Fibaro account in the Google home app results in a failure.
Anyone got the same problem?
Stefan.
10 answers to this question
Hi Stefan,
I've got the same problem. Was working perfectly before, and now it stopped.
I didn't find anything on the web so far.
Over here same problem. Already working on it with Google support for weeks... Getting insane..
when choosing the Fibaro service, its asking me for my id and pass, so I can login, but after that I should get the question which HC i would like to controll, this never happens.
I run 2 Homecenters,
I am on 4.58 and after upgrade it still used to work
Which firmeware do you run @gandhy77 @TripleZulu
Edited by SpaceCompany
Same problem here!! It stopped working just some days ago after the last update... does anyone has any answer or solution for it?
Do you have more than one Homecenter withing your Fibaro account ?
I also have this problem. Deleted the link and tried to redo the link, but now google home says first: "Fibaro is linked", followed after 10 secs by: "there is a problem". Utterly useless messages, with no clue how to proceed from here.
Fibaro: how do we fix this?????
hi
I have something similar but more weird tough I think I did find a way to make the fibaro id be followed by HC and login though the issue remains anyway its like this
 I had HCL backed up and installed on HC2 a few days ago. I use google home and all of my non fibaro dimmers turned into on off switches, the scenes though transfer to the google list, dont work at all (those with full on off settings). I tied everything inluding downgrading to 4.58, differet credentials on devices and ip but its either a but or some block. I think that in the initial update of HC2 the same lights were still also associated with had same account then removed, Could this have messed up things so that that it isnt getting all meta data required from the new HC or that the scenes are blocked and dimmers downgraded (which was the situation here a year ago when some countries were blocked from certain google home features). Ialso have a problem In the initial link that the dns wast set correctly and dnsleaktest  showing it was actually reverting through Germany. initially it remembers the room association of google but now I took out all google homes out of the plugs, the router was off and fibaro but still nothing. I
RE getting Fibaro beyond ID- that is as far as I got with google or fibaro. If you disconnect the router, all of your google home speakers and fibaro for a few mins and then plug them back In, and if your app isnt logged in on your device then you will get it. if the app is logged in they wont happen but in my case it didnt fix the issue. any updates or ideas?
thanks
im new, not sure it is the right thread but could be related. I had HCL backed up and installed on HC2 a few days ago. I use google home and all of my non fibaro dimmers turned into on off switches, the scenes though transfer to the google list, dont work at all (those with full on off settings). I tied everything inluding downgrading to 4.58, differet credentials on devices and ip but its either a but or some block. I think that in the initial update of HC2 the same lights were still also associated with had same account then removed, Could this have messed up things so that that it isnt getting all meta data required from the new HC or that the scenes are blocked and dimmers downgraded (which was the situation here a year ago when some countries were blocked from certain google home features). Ialso have a problem In the initial link that the dns wast set correctly and dnsleaktest  showing it was actually reverting through Germany. initially it remembers the room association of google but now I took out all google homes out of the plugs, the router was off and fibaro but still nothing. I was hoping I was at the end of a year of nightmare with the integrator now I feel this was the easy part. google and fibaro aren't coming up with ideas I hope someoone can help
than I had HCL backed up and installed on HC2 a few days ago. I use google home and all of my non fibaro dimmers turned into on off switches, the scenes though transfer to the google list, dont work at all (those with full on off settings). I tied everything inluding downgrading to 4.58, differet credentials on devices and ip but its either a but or some block. I think that in the initial update of HC2 the same lights were still also associated with had same account then removed, Could this have messed up things so that that it isnt getting all meta data required from the new HC or that the scenes are blocked and dimmers downgraded (which was the situation here a year ago when some countries were blocked from certain google home features). Ialso have a problem In the initial link that the dns wast set correctly and dnsleaktest  showing it was actually reverting through Germany. initially it remembers the room association of google but now I took out all google homes out of the plugs, the router was off and fibaro but still nothing. I was hoping I was at the end of a year of nightmare with the integrator now I feel this was the easy part. google and fibaro aren't coming up with ideas I hope someoone can help
thanks
Been a fibaro smart home and google home user for years, but this time the integration has been broken for good.
I am able to unlink the smart home from Google home but not able to link it back. It has now been weeks trying to contact Google home support and fibaro support but all efforts in vain.
Now i am left with broken routines and withered automation.
Anyone has the solution to problem or facing the same issue?
@gdsekhonwhat problem with linking you got? error when you eneter login and password or google not dicover new dewices?
Have you checked command sync my devices?
Fibaro smart home account does not add to Google home. All the devices are available within Yubii app. The prblem is with linking back Fibaro with Google home and thereby giving voice commands to control devices. Sync my devices will only work if the integration between Fibaro Smart home and Google home is in place. If you unlink your Fibaro smart home with Google home, i doubt that you will be able to link it back again
