HC3 + Android Home Center no custom icons
michal85pl
Does anyone know how to solve the problem of not displaying custom icons in the Android Home Center App?
16 answers to this question
  • 9 godzin temu, Thomasn napisał:
    Restart the app when you are in your home network. It helps by Homecenter2
    With HC3 id doesnt hrlp...
    probably not, i guess there are more of us ...
    I have the same problems, instead of the selected icons I see a ? (question mark).
    Same here.
  • Any updates? Still does't have custom icons for hc3 devices. For HCL same custom icons works fine.
    Guest Freddan67
    No solution to this yet. After all, no new version of the app has been released either
    You must be logged in locally (not via the cloud) to upload your icons. When you upload a new, custom icon in the administration of your HC3, you have to close (kill) the phone application (not just hide or put it to sleep). When you restart the application, all graphics are synchronized. This applies to any icons as well as widgets.
    MN
    MN
    It doesn't work with HC3, at least with mine.
    I'm sorry about your problem.
    Don't have a problem with the size of the icons?
    I made a couple of icons for better orientation between scenes for my family.
    Try to use them:
    Same for me, no custom Icons in App. In Homecenter 3 they appear.
    But with HC3 i not can use the old App... so i hope Fibaro will fix this Problem soon.
    Edited by steffu
  • W dniu 31.05.2020 o 13:30, antoniopll napisał:
    Solved in last update
    No, it still does't work.
    I had the same problem (HC3 5.050.13 + Android 9 + FIBARO Home Center 1.9.0).
    Solution:
    1. On HC switch Secure Connection to "http" only.
    2. On FIBARO Home Center "log in offline", icons will be downloaded
    edit: after switching to "http" only, you can log in with your Fibarou Cloud account and icons will be downloaded.
    Edited by danidani
    new solution
