Problem adding HC2 Gateway
Jetpower
Hi all,
Can anyone please advise?
When I click "add remote gateway" in HC2, the auto search fails every time, though if I run the program " Fibaro Finder" from my PC desktop then all Home Centers are found straight away.
So, I then add the gateway manually and all seems ok, until the imported HC2 is displayed and I noticed that the serial number of the Gateway device is missing.
My devices don't really seem to be working in harmony with each other and there are definite issues with my system talking correctly to my Fibaro ID, incorrect name and so on, but remote access does work every time.
Does anyone have ideas on what this may be, at the moment I presume it's a Fibaro bug.
Many Thanks
Adrian
