  • 7
HC3 and Hue?
nicman
Hi everbody!
I just bought the HC3 after using Homey for quite a while and starts to wonder if i just invested a lot of money down the drains?
The problem i have is that i can not see any Philips Hue lights in the Iphone app... I can se them in the Dashboard in my computer but not in the app..
I am doing something wrong? Can I get it to work?
Thank you all in advance for some guidance.
BR
Nick
Edited by nicman
@petrkl12 I can recommend the multi-file QA support in latest fibaroapiHC3 -I'm debugging, building, and deploying EventRunner4 as a 7 files QA. Probably >5000 lines of code.
@petrkl12 Hi, can i take part in the tests, too? I have a HC3 and HUE light bulbs as well as sensors and various, i would be interested in testing and wating to have you not already found a translator for the italian language...
Edited by LordSata
New version of QA Hue is ready for beta testing incl.:
- power consumption calculated based on hue types and number of bulbs in groups
- icons for press buttons in switches
- simply - everything is there :)
Edited by petrkl12
Here is the files:
Enjoy with testing :)
Edited by petrkl12
  • Like 3
Translation for Italian language is welcome :)
What is done: en,cz,de,se,nl,sk,fr,ru
Of course, this is in italian:
    it={
      stateNone="Nessuno",colorLoop="Color loop",lblAlert="Allerta:",lblEffect="Effetto:",lblBrightness="Luminosita’",lblHue="Colore",lblSaturation="Saturazione",lblCt="Temperatura colore",lblTransition="Velecita’ Transizione",btnOn="On",btnOff="Off",btnOnOff="On/Off",btnSceneSet="Imposta",lblState="Stato:",stateOn="On",stateOff="Off",stateOnPartially="Parzialmente Acceso",lblScene="Scena:",lblLastUpdate="Ultimo Aggiornamento:",btnRefresh="Aggiorna",lblPowerCons="Consumo Energia:",lblVersion="Versione QA:"
it={
      lblLastUpdate="Aggiornato:",btnUpdate="Aggiorna",lblBattery="Batteria:",lblLastAction="Ultima Modifica:",lblTemperature="Temperatura °C:",lblPresenceText="Presenza:",lblLightLevel="Potenza Luci:",lblDark="Oscurita':",lblDayLight="Luce del Giorno:",lblButtonText="Bottone:",lblButtonID="ID Bottone:",stateNone="Nessuno",stateUnknown="Stato Sconosciuto",stateYes="Si",stateNo="No",stateBtnOn="On",stateBtnOff="Off",stateBtnDimUp="Dim più",stateBtnDimDown="Dim meno",stateBtnInitP="Pressione iniziale",stateBtnHold="Manitieni premuto",stateBtnShortR="Pressione Rapida",stateBtnLongR="Pressione Lunga",stateBtn1="Bottone 1",stateBtn2="Bottone 2",stateBtn3="Bottone 3",stateBtn4="Bottone 4",lblVersion="Versione QA:"
Edited by LordSata
On 8/16/2020 at 9:47 PM, petrkl12 said:
Here is the files:
327kb and minimised :-)
:) tax for doing things foolproof and user friendly :)
and as you can see there are also QAs for lights, sensors etc. inside
Edited by petrkl12
Hello
I downloaded your HUE QA.
-How can I remove on a simple way the number in front of the HUE light name?
- Does it come back after an udate?
- or must I rename all my HUE lights in the scenes?
Please advice,
//Sjakie
In Settings/Devices you can change name of any devices
Yes, of course - means there will be still your changed name. Name is only generated during creating process.
No, you don't need to change anything. Number of QAs will be same and also names, your changes in variables, etc.
Edited by petrkl12
mmmh,
I started to changes names and HC3 in a loop,rebooting, recovery, select repair, rebooting, rebooting, recovey.......
OK restore factory and reverted to back up 4 days ago
Now my name is Murphy.
HC3 clean and ..... we will see
getting warning IKEA bulb
for your information I am using ER4 also
 and jgab
Regretley if I use one or the other HUE is fibaro.call(95,'turnOn")  or of BUT Lights is off and stays off.
What can I do now?
Changing name of QAs should not have any impact but I don't know what you have in your box.
Ikea bulbs - could you copy that warning message because there should be also type of bulb and I will need power consumption for it (minimum=switch off device and maximum=switch on and white light and max.bri)
TurnOn should work. As I see you have syntax problem with ' and "
Edited by petrkl12
Greetings, i installed your app, but it can not find my hue bridge in your qa.i tried scan,
I tried setting a name and ip in variable , reseting hue bridge, ia there something that i am missing?
 In Variables in HueMain you have to setup:
     - HueBridgeName1     - you can choose any name of your bridge - it can be whatever - allowed characters: a-z, A-Z, 0-9, _ - for example MyBridge1
     - HueBridgeIP1    - IP address of your bridge for example 192.168.1.200
and Save - HueMain should start if everything is OK
And than you have 2 options:
a)  you know your user in bridge - you can add it to Variables  - item HueUser1  ie. vPCj123VmJ18uWSHqpXfidxq5sjsP1q4Wi6DiCm
b) you can create user in HueMain - last part - button Create user (you will need physical access to your Hue bridge and press button there)
/monthly_2020_08/image.png.078d55fa02de5783311984ab0ee3b3fb.png" />
New version of HueMain - 2.25 (also new version of Hue Switch inside)
Changes:
- better support of hue switches (central scenes)
- added some Ikea Bulbs to measure correctly power consumption (I have only Philips Hue - for adding more Ikea bulbs I need to know type of bulb [in logs as a warning], minimum [light off] a maximum power consumption [usually white light with max brightness])
- some minor changes
How to update already running HueMain (if there is not visible New version please press button Refresh labels):
/monthly_2020_08/image.png.eda03f8f9607ae4bea0f43605f379ef1.png" />
or you can wait till 3am and new version will be installed automatically (default option in Variables) :)
Edited by petrkl12
do you have still issues saving (human readable) formated lua?
Thanks , it worked. :) i know that is stillmtesting app, but you are doing fine job, thanks for sharing.
I migrated from smartthings , thought fibaro is more stable, but boy i was wrong.
