Guest kallecux
Hello! - Happy Easter!
I try to play with the new MQTT-functionality in QA's, but im am not successful.
There i have a MQTT broker on Hassio and this code on HC3:
When i save the QA i get this message on HC3:
[13.04.2020] [13:33:33] [DEBUG] [QUICKAPP353]: onConnected: {"sessionPresent":false,"returnCode":0}
The Broker says this:
1586777612: New connection from 192.168.3.116 on port 1883.
[INFO] found hc3 on Home Assistant
1586777613: New client connected from 192.168.3.116 as randomjdtfpexjvy (p2, c0, k0, u'hc3')
So i think everything is OK, but i get no:
- onSubscribeMessage when the QA started
- onPublished Message when i toggle the switch
Is there anybody who can give me a hint?
Thanks in advance.
Karl Heinz
Edited:
When i toggle the QA Switch, the message is transferred to the broker and the other clients (NodeRed-Cient), but the function onPublished is NOT called!
I think the callback / envent is not executed, so i can not get the subscribed data.
12
7
5
Nov 20
10
Jun 25
6
May 14
4
Apr 16
4
jgab 13 posts
Firepeet 12 posts
Rait 7 posts
Jamie 5 posts
Nov 20 2021
Jun 25 2022
May 14 2020
Apr 16 2020
10der
.publish != :publish so please replace Please login or register to see this code. Please login or register to see this code.
petergebruers
Your call self.client:subscribe("#") Appears last in the "init" function but... It executes before the client actually connects, so it does not actually subscribe to anything. Wireshark i
jgab
52 answers to this question
