Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
@Krikroff Thank you guy ! This one was expected from lot of us !
EDIT:
Not  yet available on the marketplace, i'll have to wait :)
Edited by Tony270570
  • It's in progress ;)
  • Hum... Home office it's more work for me unfortunately!
    But i am an insomniac guy ?
    Excellent work, @Krikroff
    With TTS also planned, it seems Sonos finally will be the audio/voice part of HC3 and my smart home.
    Starting to regain faith in the Fibaro smart home. Thanks to you. Great work!
    To me this is significant. Through QuickApps, developers not directly associated with Fibaro, can create integrations like this. I hope we'll see a lot more to come.
    I think this is superb for integrating non-Z-wave devices with Fibaro Home center. Now, I wonder when Fibaro will release a tool for users /third parties to make their own templates for Z-wave devices. Too long we've been dependent on Fibaro to make all templates themselves. For some devices, for years, without any reason to believe Fibaro ever intend to make that complete integration through a template.
    I'll happily try out this QA. Thanks again, @Krikroff. Sleep well!
    Unfortunately, the QuickApp is probably not yet activated, or I cannot find it ?
  • Hum... the QA is back in review in market place.
     I hope it will not take too long, support for radio stations via TuneIn will be ready at the end of the week, then support for playlists then, TTS will not be forgotten of course ;)
  • available on the marketplace ?
    Great @Krikroff! I tried it with two of my Sonos Zone Players, a Play:1 and a AMP. But neither is working..
    I imported the QA, changed IP address and saved. Afterwards I see isConfigured changed to true. I also see a UID RINCON value appear. Both players have a static IP.
    When I press any button it takes 5 seconds before I see "Action called".  But it's not doing anything. I also deleted and re-imported.
    Tried to enter IP from a Sonos, but it does not work, the commands take about 10 seconds to be displayed, but the Sonos Box does not respond
    Same here.
    Tried different TCP Port wich gives a connection error.
  • Obviously the beginnings are difficult, sorry :( but it's strange, the QA has been successfully tested on 2 HC3 before its publication.
    1. Everyone is using the firmware v5.030.45 ?
    2. Use the coordinator's IP exclusively for the moment
    3. Please add a "debug" variable and check debug console.
    Do you have any error in
    Thanks in advance for your feedback
    1 hour ago, Everaars said:
    Same here.
    This behavior is typical when an Quick APP crashes ...
    I am going to import with the file from the market, maybe just that! because i tested few minutes ago  moment on a distant controller with my local file and it works.
    Market place file tested, no issues.
    I'm waiting for your feedback (with debug variable added), a big thank you
    Edited by Krikroff
    [21.04.2020] [11:32:02] [ERROR] [QUICKAPP366]: QuickApp crashed
    [21.04.2020] [11:32:02] [ERROR] [QUICKAPP366]: line: 815 attempt to index a nil value (field '_attr')
    After the installation I also had a config error, of course I have 8 Sonos and had to choose the right one. The Sonos PlugIn from Fibaro works however
    Edited by Macschimmi
    What I just noticed, when I download the file again, I have a folder with the file extension .fqa, the HC3 does not take it, only when I take the file with the name QA_Sonos_ZC_1.0.0.fqa in the folder, it is installed
    Sonos Quick App
    Doesn't work
    Even when the button is pressed
    Doesn't work
    But the Home Center 3 plug-in works fine.
    In debug mode
    Error not found
    Sonos Quick App does not work
    It works fine, the plugin
    /monthly_2020_04/2.PNG.433dafc9a61b8cafbbc3170b76fc26a9.PNG" />
