Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
  • Happy Holidays - joyeuses fêtes - Wesołych Świąt - Frohe Weihnachten ! ?
    Small update today with new 1.3.8 (in review on market since yesterday)
    • Add in variables panel, "notification" variable to enable or disable the "Device notification error", when disabled the QA trace the message in QA console only
    • Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
    I wish you a Happy Holiday season.
    Best regards,
    Jean-Christophe
    • Like 5
    Best regards,
    Jean-Christophe
    Looking forward to test - I guess i need to wait for the markedplace release ?
  • The latest version has been under review since Dec 23.
    Hello @A.Socha, can you do something?
    Happy holidays season :)
    • Thanks 3
    Available on the Fibaro Markeplace ?
    Always in review on the Fibaro marketplace.
    Available directly here:
    @tinman, You can grab it and post on your site ?
    Edited by Krikroff
    • Like 4
    • Thanks 2
    cool thanks, got it and updated site!
    thanks krikoff best of best
    Edited by minsad79
    On 12/21/2020 at 1:41 PM, jgab said:
    Yes, in ER4 you can do anything :-)
    You can always trigger on centralSceneEvents from the Matrix and send appropriate commands to the Sonos QA
    Instead of send startLevelIncrease and stopLevelIncrease you could have a rule that repeat sound level increase starting when it sees 'HeldDown' to it sees a 'Released'.
    Hi Jan - I tried this
    HI Jan
    The two togglePlay works fine.
    the volume control has an issue, at least on my HC3. When Helddown for lets say 2 seconds and then release, it has cued up so many Helddown commands, so is continue incVolume or decVolume for at least 10 seconds.
    My HC3 runs Children of Hue, EV4 - 3-4 other QA and around 50zwave devices. NO Scenes - they are all migrated to EV4
    Would that be something you have heard about?
    HI Jan
    Well, it kind of makes sense. It takes some times for the sonos QA to send the command, but ER4 process key events as fast as possible.
    So, either the sonos QA implements startLevelIncrease and friends, making it simple - or ER4 can listen to the sonos QA actually changing the volume and pace the commands accordingly.
    Let me come back with a rule that should fix that,.
    ohhh - Yes Please? and my COH also have a little afterslip - but not as close as the SONOS
    On 4/25/2020 at 11:16 AM, Krikroff said:
    Hello @olekenneth,
    Behind the scene in the Sonso Upnp world, a complete environment consists of ZoneGroups, the details:
    ZoneGroups = a set of ZoneGroup
    ZoneGroup = a room, composed of one or more members (ZoneGroupMember) with a dedicated ID
    ZoneGroupMember = One Sonos device (Only one member can be the coordinator of the group to which he belongs) identified by unique ID (UUID)
    In real life for example, if in your living room you have a stereo pair (Play:1) with a sub:
    ZoneGroup: "Living Room" - Coordinator: Play:1 - L
    1. ZoneGroupMember: Play:1 - L (group coordinator, its IP must be declared in the Quick App)
    2. ZoneGroupMember: Play:1 - R
    3. ZoneGroupMember: SUB
    1 room = 1 zone group = 1 Quick App :)
    NB: The features for grouping rooms, volume, party mode, making it visible or invisible, etc. are different things
    You have a set of ZoneGroup (your rooms composed with members aka your physical devices) in ZoneGroups.
    Room 1 = 1 Quick App
    Room 2 = 1 Quick App
    Room 3 = 1 Quick App
    Room 4 = 1 Quick App
    Thank you for developing the SONOS QA.
    I'm looking for Scene or EV4 examples setting up "party mode" that would be used for internal Alarm.
    I see getCommands for ZoneGroups
    I found some description at .
    I'm using a setup like this
    Just saw this comment in the markedplace - so i will probably need to wait :-)
    ROADMAP
    Support for Group
    Support for TTS
    Edited by ChristianSogaard
    P
    On 4/20/2020 at 12:14 PM, Krikroff said:
    • Please login or register to see this link.
    Current version: 1.3.8
    Date: 24/12/2020
    FUNCTIONS
      • Initiate playback
    •  Device Properties
    • Enable Debug Mode
    Examples:
      fibaro.call(ID_QUICKAPP, "setVolume", 10, "MASTER")
      fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "MASTER")
      fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3, true, 20, 8000)
    Version 1.3.8
    Version 1.3.1 RC
    • Add seek command
    Version 1.1.1
    Version 1.0.3
    Version 1.0.2
    Version 1.0.0
    ROADMAP
    • Support for Group
    • Support for TTS
    Thanks again Kirkoff!
    Is there a way I can upgrade an existing QuickApp Sonos device from 1.3.1 to 1.3.8, without having to create a new DeviceID & deleting the old one?
    Would going into the original Device, entering the edit mode and replacing the main set of 1.3.1 code with the ones from a 1.3.8 work, or is there an alternative?
    Thanks again!
  • No alternative, I had asked Fibaro if it was possible to integrate an update mechanism but I believe that it is not in the priorities ;)
    Hi Jan - wondering if this is possible to solve? . I tried myself, but no luck
    My thinking was that when the Sonos controller updates its volume property there will be a trigger
    Then we can set a flag that the volume have been changed, and only update volume in the loop if volume changed?
    It may actually turn out to be too slow
    If it's too slow, you could try to make the loop faster
    incVolume = rule("@@0.5 ......
    that would set the loop to 500ms
    I haven't tried it myself.
    Merci ? - I will test, and get back with the result :-)
    I think @jgab did an update mechanism in his EV4?
    Thanks again!
    Thank you @Krikroff for developing this!
    I had some issues earlier with - Increase or decrease player volume - just want to mention.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "MASTER"). - this dont work for me
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master") - this works for me
    If findings are correct, i think its only documentation needed to be updated.
    P
  • I’ll check asap?
    Hi @jgab - thank you for this EV4 rule.
    I tested it - an it didn't work at first try.
    Problem was this rule
    rule("#device{id=sonos_kitchen,property='volume',value='$new',old='$old'} & new~=old => VC=true")
    never triggered, but i got you idea, and made this small change
    and now it works - Great work Jan, Thank you...
    P
