Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
Hi @Krikroff ,
Newbie here...
How can i add a radio station in the buttons?
And how can i add Spotify playlists in the buttons?
Do i have to edit the LUA code ? Or can i save a list/station while playing?
Thx in advance. QA looks great.
Greetz, Joeri
Edited by joerib1
9 minutes ago, joerib1 said:
Hi Krikroff,
Newbie here...
Thx in advance.
Greetz, Joeri
@joerib1 Radio station is taken from you SONOS favorites. automatic.
On 12/24/2020 at 3:13 PM, Krikroff said:
Happy Holidays - joyeuses fêtes - Wesołych Świąt - Frohe Weihnachten ! ?
Small update today with new 1.3.8 (in review on market since yesterday)
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", when disabled the QA trace the message in QA console only
  • Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
I wish you a Happy Holiday season.
Best regards,
Jean-Christophe
 @ChristianSogaard And i assume that Krikroff didn't remove it in v 1.4
It works on my Second installation! radio and spotify playlist.
Thank you very much!
(i will reinstall my first installation)
Hey @Krikroff :)
First of all thanks for the amazing QA. It baffles me that Fibaro doesnt do this themselves, nor Sonos 😕 As a developer myself, I know the time this takes.
Something weird happened today. My QA worked but did not load the Radios. So I decided to remove it and reinstall, but after that, nothing worked 😕 It does load some of the data as you can see from the screenshots. But when I click any of the buttons I get the crash with the "attempt to index a nil value (field '?')" error.
Here's the debug log, and attached are some screenshots. If had some install and reinstall issues with my HC before that only a remote support agent could fix. The HC3 system seems very unstable. Who knows, it might not even be something to do with your QA.
Any idea what could be up?
Sonos OS is OS2, build 63290210, version is 13.1.4.
Edited by StanS
