Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
Just now, Winnetoe said:
can`t find the qa ?
  • 52 minutes ago, minsad79 said:
    Error not found
    Sonos Quick App does not work
    QA seems connected, please select ERROR tag in console
    /monthly_2020_04/image.png.8e5f8261394a7ce39ad13ba8e2c11c42.png" />
    Thanks @minsad79
    1 hour ago, Macschimmi said:
    QA_Sonos_ZC_1.0.0.fqa
    Yes @Macschimmi,  unzip the archive in a separate folder and upload the file QA_Sonos_ZC_1.0.0.fqa  ;)
    Edited by Krikroff
    [21.04.2020] [11:57:47] [ERROR] [QA_SONOS_369]: No route to host
    [21.04.2020] [11:57:47] [ERROR] [QA_SONOS_369]: httpClient error: No route to host
  • 1 minute ago, Macschimmi said:
    No route to host
    please post screenshot about variables
    5 minutes ago, Krikroff said:
    품질 관리가 연결된 것 같습니다. 콘솔에서 오류 태그를 선택하세요
    감사
    Quality management error indication
    It doesn't work when I press the button
    Thanks in advance
  • please add a debug variable ;)
    @minsad79, please remove Tag QA_SONOS_708
    (identified bug in firmware when error ;) )
    1 minute ago, Krikroff said:
    디버그 변수를 추가하십시오 ;)
    Variables in list
  • Just now, minsad79 said:
    Variables in list
    seems ok for me..
    Just now, Krikroff said:
    괜찮아 보인다 ..
    @ minsad79 , 태그 QA_SONOS_708를 제거하십시오
    (오류시 펌웨어에서 확인 된 버그  )  ;)
    I think I found the error
  • Thank you I will check and try to reproduce the error in another environment
    8 minutes ago, Krikroff said:
    다른 환경에서 오류를 확인하고 재현하려고합니다.
    Thank you for your contribution
  • @minsad79 Check your PM ;)
    Edited by Krikroff
    Hi @Krikroff, same problem here also...
    /monthly_2020_04/afbeelding.png.2434b2ec2ae76ae316f779875a7dd851.png" />
    [21.04.2020] [14:52:02] [ERROR] [QUICKAPP81]: QuickApp crashed
    [21.04.2020] [14:52:02] [ERROR] [QUICKAPP81]: line: 815 attempt to index a nil value (field '_attr')
    Edited by Bodyart
    In debug mode:
    /monthly_2020_04/afbeelding.png.9922c0a1c8697e223f0a90ea7923e92e.png" />
    Edited by Bodyart
  • Yes same...
    It's under debug thanks for your patience ;)
    2 minutes ago, Bodyart said:
    In debug mode:
    blue theme: great :)
    @Krikoff
    I have the same error with my 5 room Sonos system. It appers the error :-
    [21.04.2020] [15:59:02] [ERROR] [QUICKAPP173]: QuickApp crashed[21.04.2020] [15:59:02] [ERROR] [QUICKAPP173]: line: 815 attempt to index a nil value (field '_attr')
    If I group the entire system when playing music the error goes away.
    But none of the buttons work except for the stop button and volume slider. Cannot get the pause, mute to work on any Sonos rooms either individualy or as group.
    Graham
  • Version 1.0.2
    Available on the market after passing the "review" status
    Please excuse me for the inconvenience ☺️
    Edited by Krikroff
