Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
HI  Krikroff
NEW  Version 1.0.2 sonos quick app
The modified version works so attractively
Thank you for your contribution and dedication
From Korean users
  • Hum... I just sent an email to market place Team to request unlocking ;)
    Absolutely nothing important but I would like to be able to change icon if possible. @Krikroff You should have a big thank you. You did this well
    Just installed new verison on 6 room system, work perfectly. Thank you for your excelent work on this, used this a lot on my old HC2 setup.
    Looking forward to TTS later on as with my old system had lots of anouncements depending on different scene activated played through Sonos speakers. Also MP3 track playback on scene activations, like wakeup with a happy MP3 track in the morning,
    Thank you once again for this, making my HC3 more like what I have been use too.
  • @A.Socha, i'am sure of it :)  Thanks
    sorry had no time to send you the debug, I just tried the 1.0.2 version and it works, thank you!
    Well, I still have problem with 1.0.2
    I have an old gen1 Play:5 with the latest sw. It's one device in one group/room.
    Maybe it's worrisome that the Series ID reports nil - but I promise it's a legit Sonos device :-)
    Anyway, it crashes in the response callback in Sonos:getZoneGroupState(h)
    More specifically at
    The 'I' structure for me is
    that then crashes. It seems like the structure is missing a level.
    If I modify the code to
    it seems to work for me, can play/pause and get status updates - but that would break for people that it works for now.
    Anyone else still having problem or is it only me?
    Hi @Krikroff
    I will test some more, but for me the QA seems to not work properly on my Sonos: Play 1. Occasionally (seldom), I can manage to get it to play if I press the Play button. I haven't had any luck to get it to stop or change volume. I have the Fibaro Sonos module installed and it works perfectly.
    Software Version:54.2-72160 - Series ID:A200
    [2020-04-24] [09:41:01] [DEBUG] [QA_SONOS_219]: componentUpdate_zoneLabel
    [2020-04-24] [09:41:01] [TRACE] [QA_SONOS_219]: [ZoneGroupTopology:GetZoneGroupState:response]
    [2020-04-24] [09:42:00] [DEBUG] [QA_SONOS_219]: debug mode: true
    [2020-04-24] [09:42:00] [DEBUG] [QA_SONOS_219]: componentUpdate_footerLabel
    [2020-04-24] [09:42:00] [DEBUG] [QA_SONOS_219]: XmlSoap class initialized!
    [2020-04-24] [09:42:00] [DEBUG] [QA_SONOS_219]: Sonos class initialized!
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [[GetZoneGroupAttributes:GetZoneGroupAttributes]
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [ZoneGroupTopology:GetZoneGroupState]
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [GetZpStatus]
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [DeviceProperties:GetLEDState]
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [RenderingControl:GetVolume]
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [RenderingControl:GetMute]
    [2020-04-24] [09:42:00] [TRACE] [QA_SONOS_219]: [RenderingControl:GetLoudness]
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [AVTransport:GetTransportInfo]
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [RenderingControl:GetVolume]
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [RenderingControl:GetMute]
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [RenderingControl:GetLoudness]
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [AVTransport:GetMediaInfo]
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [[GetZoneGroupAttributes:GetZoneGroupAttributes:response]
    [2020-04-24] [09:42:01] [DEBUG] [QA_SONOS_219]: [GetZoneGroupAttributes:response] <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetZoneGroupAttributesResponse xmlns:u="urn:schemas-upnp-org:service:ZoneGroupTopology:1"><CurrentZoneGroupName>Bedroom</CurrentZoneGroupName><CurrentZoneGroupID>RINCON_xxxxxxxxxxxxx</CurrentZoneGroupID><CurrentZonePlayerUUIDsInGroup>RINCON_xxxxxxxxxxxxx</CurrentZonePlayerUUIDsInGroup><CurrentMuseHouseholdId>Sonos_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxBosL_R</CurrentMuseHouseholdId></u:GetZoneGroupAttributesResponse></s:Body></s:Envelope> 0
    [2020-04-24] [09:42:01] [DEBUG] [QA_SONOS_219]: [GetZoneGroupAttributes:response] CurrentZoneGroupName: myroom
    [2020-04-24] [09:42:01] [DEBUG] [QA_SONOS_219]: [GetZoneGroupAttributes:response] CurrentZoneGroupID: RINCON_xxxxxxxxxxxxx:0000000
    [2020-04-24] [09:42:01] [DEBUG] [QA_SONOS_219]: [GetZoneGroupAttributes:response] CurrentZonePlayerUUIDsInGroup: RINCON_xxxxxxxxxxxxx
    [2020-04-24] [09:42:01] [DEBUG] [QA_SONOS_219]: [GetZoneGroupAttributes:response] CurrentMuseHouseholdId: Sonos_xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    [2020-04-24] [09:42:01] [DEBUG] [QA_SONOS_219]: componentUpdate_zoneLabel
    [2020-04-24] [09:42:01] [TRACE] [QA_SONOS_219]: [ZoneGroupTopology:GetZoneGroupState:response]
    Edited by robw
    11 minutes ago, robw said:
    Hi @Krikroff
    Thank you!
     - I'm not alone! :-)
    (It actually crashes at GetZoneGroupState:response but it happens in a httprequest callback so there is no error message logged. Then the QA restarts and it repeats). @Krikroff maybe wrap the callbacks in pcalls to trap and log errors?
    Hi!
    I'm really happy about this QA but unfortunately it doesn't work for me...
    I press the button and it takes about 5 sec to popup confirmation but Speaker doesn't react.
    LOG:
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: debug mode: true
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_footerLabel
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: XmlSoap class initialized!
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: Sonos class initialized!
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [[GetZoneGroupAttributes:GetZoneGroupAttributes]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: debug mode: true
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [ZoneGroupTopology:GetZoneGroupState]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [GetZpStatus]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [DeviceProperties:GetLEDState]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: componentUpdate_footerLabel
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [RenderingControl:GetVolume]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [RenderingControl:GetMute]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: XmlSoap class initialized!
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [RenderingControl:GetLoudness]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: Sonos class initialized!
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [[GetZoneGroupAttributes:GetZoneGroupAttributes]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [ZoneGroupTopology:GetZoneGroupState]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [AVTransport:GetTransportInfo]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [GetZpStatus]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [DeviceProperties:GetLEDState]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [RenderingControl:GetVolume]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [RenderingControl:GetMute]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [RenderingControl:GetLoudness]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [AVTransport:GetMediaInfo]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [DeviceProperties:GetLEDState:response]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [AVTransport:GetTransportInfo]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [DeviceProperties:GetLEDState:response] LEDState: On
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_optionsLabel [Volume: 00] [Mute: OFF] [Loudness: ON] [LED: ON]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [RenderingControl:GetVolume:response]
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [AVTransport:GetMediaInfo]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [RenderingControl:GetVolume:response] CurrentVolume: 12
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_volumeSlider arg[value] 12
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] ZoneName: Salon
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_optionsLabel [Volume: 12] [Mute: OFF] [Loudness: ON] [LED: ON]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] ZoneIcon: x-rincon-roomicon:office
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] LocalUID: RINCON_949F3E10491401400
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] SoftwareDate: 2020-04-06 09:38:13.763254
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] SoftwareVersion: 56.0-76060
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] SeriesID: A200
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [RenderingControl:GetMute:response]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] IPAddress: 192.168.0.100
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [RenderingControl:GetMute:response] CurrentMute: false
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZpStatus:response] MACAddress: 94:9F:3E:10:49:14
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_muteButton arg[state] false
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: componentUpdate_zpStatusLabel
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [[GetZoneGroupAttributes:GetZoneGroupAttributes:response]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZoneGroupAttributes:response] <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetZoneGroupAttributesResponse xmlns:u="urn:schemas-upnp-org:service:ZoneGroupTopology:1"><CurrentZoneGroupName>Salon + 1</CurrentZoneGroupName><CurrentZoneGroupID>RINCON_949F3E10491401400:862134347</CurrentZoneGroupID><CurrentZonePlayerUUIDsInGroup>RINCON_949F3E10491401400,RINCON_347E5C1927EE01400</CurrentZonePlayerUUIDsInGroup><CurrentMuseHouseholdId>Sonos_z8gO5VRBdkIHAbgomni37VNCKJ.Uu73ayYKNZ_geCfHkauo</CurrentMuseHouseholdId></u:GetZoneGroupAttributesResponse></s:Body></s:Envelope> 0
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [RenderingControl:GetLoudness:response] <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetLoudnessResponse xmlns:u="urn:schemas-upnp-org:service:RenderingControl:1"><CurrentLoudness>0</CurrentLoudness></u:GetLoudnessResponse></s:Body></s:Envelope> 0
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [RenderingControl:GetLoudness:response] CurrentLoudness: false
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_loudnessButton arg[state] false
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZoneGroupAttributes:response] CurrentZoneGroupName: Salon + 1
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZoneGroupAttributes:response] CurrentZoneGroupID: RINCON_949F3E10491401400:862134347
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_optionsLabel [Volume: 12] [Mute: OFF] [Loudness: OFF] [LED: ON]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZoneGroupAttributes:response] CurrentZonePlayerUUIDsInGroup: RINCON_949F3E10491401400,RINCON_347E5C1927EE01400
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: [GetZoneGroupAttributes:response] CurrentMuseHouseholdId: Sonos_z8gO5VRBdkIHAbgomni37VNCKJ.Uu73ayYKNZ_geCfHkauo
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_287]: componentUpdate_zoneLabel
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] ZoneName: Biuro
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] ZoneIcon: x-rincon-roomicon:living
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] LocalUID: RINCON_347E5C1927EE01400
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_287]: [ZoneGroupTopology:GetZoneGroupState:response]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] SoftwareDate: 2020-04-06 09:38:13.763254
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] SoftwareVersion: 56.0-76060
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] SeriesID: A200
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] IPAddress: 192.168.0.101
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZpStatus:response] MACAddress: 34:7E:5C:19:27:EE
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_zpStatusLabel
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [[GetZoneGroupAttributes:GetZoneGroupAttributes:response]
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZoneGroupAttributes:response] <s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetZoneGroupAttributesResponse xmlns:u="urn:schemas-upnp-org:service:ZoneGroupTopology:1"><CurrentZoneGroupName></CurrentZoneGroupName><CurrentZoneGroupID>RINCON_949F3E10491401400:862134347</CurrentZoneGroupID><CurrentZonePlayerUUIDsInGroup>RINCON_949F3E10491401400,RINCON_347E5C1927EE01400</CurrentZonePlayerUUIDsInGroup><CurrentMuseHouseholdId>Sonos_z8gO5VRBdkIHAbgomni37VNCKJ.Uu73ayYKNZ_geCfHkauo</CurrentMuseHouseholdId></u:GetZoneGroupAttributesResponse></s:Body></s:Envelope> 0
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZoneGroupAttributes:response] CurrentZoneGroupName: table: 0x24e4e6f0
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZoneGroupAttributes:response] CurrentZoneGroupID: RINCON_949F3E10491401400:862134347
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZoneGroupAttributes:response] CurrentZonePlayerUUIDsInGroup: RINCON_949F3E10491401400,RINCON_347E5C1927EE01400
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: [GetZoneGroupAttributes:response] CurrentMuseHouseholdId: Sonos_z8gO5VRBdkIHAbgomni37VNCKJ.Uu73ayYKNZ_geCfHkauo
    [24.04.2020] [10:06:01] [DEBUG] [QA_SONOS_288]: componentUpdate_zoneLabel
    [24.04.2020] [10:06:01] [TRACE] [QA_SONOS_288]: [ZoneGroupTopology:GetZoneGroupState:response]
  • @Alan Klepacz, @robw can you confirm that you are using the latest version 1.0.2 ?
    Edited by Krikroff
    Yes.
  • Thanks @robw,
    @jgab, could you replace
    with
    And send me the reponse ?
    /monthly_2020_04/image.png.5a3c72c3c8593bca1d63e8ba74366b99.png" />
    thank you.
    2 minutes ago, Krikroff said:
    @Alan Klepacz, @robw, @jgabThe configured zone corresponds to a group of players or only one?
    For me it is a single speaker, one Sonos: Play 1.
