Quick App - Sonos Zone Controller
Krikroff
Current version: 1.5.1
Date: 17/12/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
RELEASE NOTES
Version 1.5.1
Tested with Sonos OS: S2 - Version 13.4.1 (number 66423300)
Tested with HC3 & HC3Lite v5.091.00
  • Improved support for Sonos Amp & Sonos One Gen2/SL and communication performance improvement
  • Add new volume limiter feature: an option to prevent damage with unwanted high volume
  • Add support for "Device disabled" option available in quick app advanced panel
  • Add possibility to emits custom event when initiating a playback (playing), paused and stop playback state (just declare event name used in quick app variable panel ex: "event.stopped" or  "event.playing" and the events in "General => Events". You can now triggering scenes on events) (https://forum.fibaro.com/topic/55510-create-a-scene-when-sonos-play-it-activate-a-whall-socket/#comment-235990)
  • Fix a problem occured in some cases when zone controller browse device directory and parse items Declaration (DIDL) resulting an out of service for the QuickApp
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.5.1
  • Like 17
  • Thanks 2
2 minutes ago, robw said:
For me it is a single speaker, one Sonos: Play 1.
But your speaker is assigned to a room, i.e. group?
(I guess Sono's zone, group and room concept is the same?)
Yes, it is in a zone (Bedroom).
  • Hi, problem fixed :) i post asap for testing purpose.
    Thank you for your essential feedback
    Edited by Krikroff
  • Version 1.0.3 (beta)
    -- Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
    I have simulated several use cases which I think should cover wide:
    • 1 ZoneGroup with 1 ZoneGroupMember
    • 1 ZoneGroup with 3 ZoneGroupMembers
    • 2 ZoneGroups with 1 ZoneGroupMember in each ZoneGroup
    • 3 ZoneGroups with 3 ZoneGroupMembers (1: 1xZoneGroupMember, 2: 2xZoneGroupMember, 3: 3xZoneGroupMember)
    According to your feedback I will also update on the marketplace :)
    • Thanks 4
    Thank you @Krikroff for updating this QA so quickly! :) I will test it now.
    *Edit* Well done! It works! Thank you!
    Have a nice weekend!
    Rob
    Edited by robw
    Thanks, work ok for me!
    /J
    Works here without problem :-D
    3 hours ago, Krikroff said:
    ... According to your feedback I will also update on the marketplace :)
    I had the same problem, the fix works great. Thanks
  • Thanks you to all for your feedback,  Marketplace is now up to date with the new v1.0.3 (Status: In Review)
    The next version will be v1.1.0 with support for TuneIn "My radio stations" as new feature. Hope you will like it!
    • Thanks 6
    I'm a little confused about the terminology.
    Sonos uses the terms "room" and "group". A single Sonos player (e.g. "Connect:Amp") in a room or a stereo set of two players in a room (e.g. two "Play:1"). Rooms can be grouped together.
    Of course in larger Sonos installations, there are a number of rooms and may be multiple groups.
    Maybe I'm just a little slow, but how does this correspond to your ZoneGroup examples?
    And if I have a Sonos group consisting of 4 rooms with a total of 7 physical Sonos devices, how many instances of the QuickApp do I need to run?
    Edited by olekenneth
  • Hello @olekenneth,
    Behind the scene in the Sonso Upnp world, a complete environment consists of ZoneGroups, the details:
    ZoneGroups = a set of ZoneGroup
    ZoneGroup = a room, composed of one or more members (ZoneGroupMember) with a dedicated ID
    ZoneGroupMember = One Sonos device (Only one member can be the coordinator of the group to which he belongs) identified by unique ID (UUID)
    In real life for example, if in your living room you have a stereo pair (Play:1) with a sub:
    ZoneGroup: "Living Room" - Coordinator: Play:1 - L
    1. ZoneGroupMember: Play:1 - L (group coordinator, its IP must be declared in the Quick App)
    2. ZoneGroupMember: Play:1 - R
    3. ZoneGroupMember: SUB
    1 room = 1 zone group = 1 Quick App :)
    NB: The features for grouping rooms, volume, party mode, making it visible or invisible, etc. are different things
    You have a set of ZoneGroup (your rooms composed with members aka your physical devices) in ZoneGroups.
    Room 1 = 1 Quick App
    Room 2 = 1 Quick App
    Room 3 = 1 Quick App
    Room 4 = 1 Quick App
    I still can't get it done.
    I have 2 pcs of Sonos Play 1, playing together but not as L & R.
    I'm adding first QA and it works, then I add second one with different IP and it doesn't work..
    Can you help me? :)
    Can you help me? :)
    when you have two Speakers, connected as L & R pair - which is one Sonos Zone - you need only one QA, not two - this is how Sonos works
    As I've said - they aren't working as L & R pair. They're only in group but NOT as L & R.
    yeah, blind me … NOT L&R .. but still used/paired as Group (which is Zone for QA). As only one speaker is controling what the Zone is playing, the answer is still the same, only one QA.
    Edited by tinman
    Ok, so which IP should I enter in QA? Because none of these two isn't controlling whole group..
  • Try with both and keep only the one that works ;)
    But it still doesn't controll second one.
    As I've said "none of these two isn't controlling whole group.."
    Edited by Alan Klepacz
