Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
  • I don’t understand the problem, perhaps a specific case.
    Is it possible to send me screen capture about your Sonos system information ?
  • 7 hours ago, Alan Klepacz said:
    As I've said "none of these two isn't controlling whole group.."
    I think you group two room, can you confirm that for your installation: 1 x Play: 1 = 1 Room ?
    Yes, exactly.
    I use those two speakers in two separate room but they're playing the same radio channel (it's an office), so I don't want them to work as L & R channels.
    Another probably stupid question. Is it possible to change the ICON for the QuickApp?
    I can't figure it out, and searching the forum didn't help much either.
  • Seems not supported yet in DeviceController QA
    Hi, I installed the Sonos Zone controller and and works fine. I can start and stop the Sonos from the devices tab.
    I'm a Fibaro HC3 user for 2 weeks and programmed a few simple scenes that give my a push when the door opens.
    Now I want to play the Sonos from this existing simple block scene but I cannot select the QA Sonos controller to play the Sonos?? I feel so stupid, what I'm I doing wrong?
  • Hello, actually actions are supported only in lua scene but not in block scenes, perhaps with next hc3 firmware.
    AH, that explains it! Thank you. So this means that if I want to use this in my block scene I should write a new QA with a simple Lua command to play the sonos?
    in principle yes, but remember that not all ui-actions are implemented for now, so you have to take something like multilevel switch (turnon, turnoff, setvalue available), or even more funny Colour Controller - and add your Actions into it's functions to use them in block Scenes :) Sure, the best would be to use multimedia Kind of QA device, but they don#t work for now (now even original Fibaro plugins or QAs based on them)
    Edited by tinman
    Alternatively, QA could react to customEvents? block scenes could then emit them... for play and stop etc.
    With the “debug” variable on “false” I didn’t expect all the debug lines. But I still get them. Do I have the wrong expectations?
  • :) I keep these lines during the stabilization phase until version 1.2.0 then they will only be if the debug mode is activated
  • New version 1.1.0 in review
    /monthly_2020_05/preview_1.1.0.PNG.cb62d73878a2e551ffa82cb8cd6147e0.PNG" />
    Have fun :)
    • Like 3
    Have fun :)
    How to add radio channels to the buttons?. Keep up the good job.
    Hi @Freddan67, just define then in your Sonos app and they will automatically appear in your QA buttons :-D
    Thanks. Sometimes it is that simple so amn can't even think clearly :)
    thank you so much! @Krikroff
    /monthly_2020_05/image.png.9fd19f4325969216cda19bac0b46c65c.png" />image.png.98a4ed97a2e540a60e52b7d54a821b5f.png
