Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 16
  • Thanks 2
3 hours ago, 10der said:
thank you so much! @Krikroff
How did you change icon?
    Hum... with a non official HC version or with the API ;) (device endpoint)
    I'm a little curious
    a little seceret? ok?!@Freddan67
    1) find any multisensor device (for example Humidity)
    2) click add icon
    3) upload icon
    4) leave multisensor device
    5) ask  @Krikroff to add Variable IconId
    6) add to onInit something like self:updateProperty("deviceIcon", fibaro.getVariable("IconId"));
    done
    or
    Edited by 10der
    • Like 4
    2) click add icon
    3) upload icon
    6) add to onInit something like self:updateProperty("deviceIcon", getVariable("IconId"));
    done
    Thanks. @Krikroff Is it possible to arrange?
  • @Freddan67, Honestly I prefer to wait for the official support by Fibaro but i think about a solution in parallel in case it takes too long ;)
    It's your app. You decide ?
    Hi @Krikroff,
    Coul'd you please expand the number of preset stations in one the the next version to 9, or preferably even 12? :-D
    This method we have used also in HC2 and this allows us also to change icons dynamically :-D
    8 hours ago, Freddan67 said:
    Is there any way to call a radio channel via lua ?.
    Hi @Krikroff,
    Added
    But i have used @10der solution ;)
    13 hours ago, Krikroff said:
    Thank you so much. You are the best
    Kri. hi!
    i have connected sound from my old mac-mini to my Sonos and your QA crased
    [10.05.2020] [21:12:39] [ERROR] [QUICKAPP1743]: line: 935 attempt to index a nil value (field 'desc')
    JFYI.
  • Hi, thank you for the report. Could you share more information about the file ?
    to be sensible of the fact that... your code "obfuscated" :) error here
    probably here
    w.currentURIMetaData.id=y["desc"]
    if think you should checlk
    w.currentURIMetaData != nill
  • I was talking about the audio file ;) pushed to SONOS with your MacMini
    sorry. it's not audio file...
    one moment
    so, i have setup my GB for outputing "System", set in system output to Sonos - Office
    and press key on my piano.
    HC3 reported error ? in Sonos QA
    Edited by 10der
  • Awesome :) , before I played with Protools now I use cubase on PC ...
    For your problem, I think there are no attributes associated with audio streams, this is fixed for the next version ;)
    cube is good... but my dreams is... "Reason" from propellerhead.... but $$$ :(
