Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 17
  • Thanks 2
53 minutes ago, 10der said:
"Reason"
Oleg, I was also playing with Cubase years ago, but since i use Reason the "whole world changed" :-D
Hello @Krikroff,
After using your "old" version for a long time I installed your new  "baby".
MMMh its already a teenager!
Thank you very much!
Any idea when TTS can be implemented?
//Sjakie
  • Hello @Sjakie, thank you for your comment.
    For the TTS I explore several solutions, the idea is to offer something reliable and efficient ;)
    Regards
    • Like 3
    Your QA works really well but I would like to be able to choose depending on the scenario to choose which playlist it should play. I have seen that there is something you want in, but how far away is this about?
  • Hi @Alan Klepacz
    @Krikroff this QA works really good and happy to see that you ported it to HC3, have been using the HC2 version a lot earlier.
    Any insight to when playback of “user” sounds will be available? Did use the HC2 version in my DoorBell configuration and played sounds (stored on a NAS) on a couple of my Sonos when the Smart Implant connected DoorBell button was pressed, really miss that function to get my Doorbell solution working in the HC3.
  • @JcBorgs Thank you for your encouragement ;)
    Playback of “user” sounds is already  available in internal version and logically it will be available in next release
  • @Alan Klepacz Sorry I'm not sure I understand but 5 = +5
    do the job ;)
    I'm sorry, I misunderstood you from the very beginning and thought that -5 is lowering and 5 is setting volume 5. Now I understand and work great ?
    @Krikroff : Real great app!! Looking forward to your next roadmap results! Keep up the good work!
    I just can't seem to reset the debug level. I added an extra variable called debug with value false, next to the already exiting 3 variables.  But the messages keep on going. I'm i doing something wrong?
    Edited by okidoki
  • For debug this should be active for the next update;) but with this everything is enabled by default
    When do you expect to be ready to release the next version?
  • most certainly after the next update of HC3 ;)
    Next update of HC3 is publicly available now ?
  • Sorry I'm very busy right now but it will happen ;)
    • Like 3
    Looking forward to this, only piece I have left to move from the HomeyPro to the HC3 so that the Homey can be retired (or used as a football by the kids ?).
    If you need any tester I would be happy to assist..
  • SONOS S1 Test Passed
    SONOS S2 Software Version:58.1-77280 Test Passed
    stay tuned for updates :)
    • Like 4
