Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 17
  • Thanks 2
5 hours ago, Krikroff said:
SONOS S1 Test Passed
SONOS S2 Software Version:58.1-77280 Test Passed
stay tuned for updates :)
Is your favorite playlist on the next update?
"Tuning" in everyday looking for an update..:-)
Unfortunately for me it doesn't work. I haven't made any changes and some day it stopped working with my Sonos. I have correct IP and after pressing any button on QA I have 5 sec of nothing, than popup appears but without any changes on Sonos. Can you help me?
  • Go to un variable panel. Check your IP.
    To force QA to restart, delete port variable and save ;)
    Nope, didn't solved the problem. Also I have to say that I have the same problem in my office and at two clients houses..
  • Hum strange...
    I can share with you the next version in preview for testing.
    Hi
    I try to decreae or increase the volume with this fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "MASTER")
    but noting happend , what i do wrong?
    greetings Cor
    On 6/17/2020 at 5:39 PM, Krikroff said:
    Hum strange...
    I have the exact same problem. I have, 4 sonos speakers as a surround system. A Beam, Sub and 2 x Gen5
    The settings of the variables are correct. I use the IP of the beam. After pressing one of the buttons it takes a few seconds before i see the green popup, but nothing happens.
    Also the TuneIn buttons are still empty. When in turn on the debug mode i see the right MAC-address, so there's a connection with Sonos.
    Edited by Firepeet
    /monthly_2020_07/grafik.png.316cbb8db9f980c64d5f9e842a9f4f3d.png" />
    May I asume you also filled in the port number 1400?
    Start Sonos with Sonos apl and see if you can stop, play or change volume?
    Succes,
    //Sjakie
    By any chance you use HC2 and tts?
    If not I am out off ideas.
    //Sjakie
    Hi guys,
    Does anyone already have a solution for the Sonos QA that doesn't work for me?
    All the settings are correct, but I still don't get a response.
    The standard HC3 plugin for Sonos works fine for me.
    HC3 5.031.33
    /monthly_2020_07/image.png.0bf43f7fd8d4947df503bf2ac6b20749.png" />
    @Krikroff
    With HC2 my main use of the Sonos VD is producing Sonos sounds with mp3's for Alarm, Doorbell, etc. also with use of Sonos TTS VD.
    Is the momentary version of the HC3 Sonos QA (1.1.0 referred here as 1.1.1) already capable of playing mp3 sounds? I do not need real Test To Speak.
    @KrikroffHi ...
    OFFTOPIC
    I have more of an operational question on QA development for you.
    When you post a new version to the Marketplace, it will switch to "In Review" status. This time, until Fibaro checks the code, the QA application is actually unavailable to the public. It is so?
    Your answer may explain to some users why they may not be able to see the app in the Marketplace.
    I wanted to publish a QA, it has been revised, but I have only changed the graphics of the logo and now it is in "In Review" again .. Hmmm.
    Then the question is whether not to publish your QA through the finally working Download / QuickApps section
    Thanks, eM
    If anyone has problems with the volume control, here is my solution:
    fibaro.call(ID_QUICKAPP, "setVolume", 20, "MASTER") - it does not work (error)
    fibaro.call(ID_QUICKAPP, "setVolume", 20) - works well
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "MASTER") - it does not work (error)
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5) - works well
    How can I check if there is any music playing in a zone? Which function can I use for this?
    Thanks in advance!
    Greetings,
    Chiel
    On 7/17/2020 at 4:56 PM, Firepeet said:
    Hi guys,
    HC3 5.031.33
    I got the same issue, not working for me neither.
