Quick App - Sonos Zone Controller
Krikroff
Current version: 1.4.0
Date: 15/03/2021
/monthly_2020_10/Preview_1.3.1.PNG.07af3ad8f4e892c6f2a00a8452a48bde.PNG" />
FUNCTIONS
The functions of this Quick App are:
Allowing to control Sonos Player from Home Center 3. It does support basic and advanced functions:
  • Basic Transport Control
    • Initiate playback
    • Toogle, Pause or Stop playback
    • Skip to the previous or Next track
  • Basic Rendering Control
    • Get player volume and mute state
    • Set player volume to a specific level and unmute the player if muted
    • Increase or decrease player volume
    • Get or Set or Toggle player mute state (Mute or unmute the player)
    • Get or Set or Toggle player loudness state
  •  Device Properties
    • Get or Set group LED state
  • Restart the QA Device
  • Enable Debug Mode
See Changelog / Manual for basic and advanced available actions
Examples:
  • Set player volume to a specific level and unmute the player if muted.
    fibaro.call(ID_QUICKAPP, "setVolume", 10, "Master")
  • Increase or decrease player volume.
    fibaro.call(ID_QUICKAPP, "setRelativeVolume", -5, "Master")
  • Initiate playback.
    fibaro.call(ID_QUICKAPP, "play")
  • Play a file at volume 10 with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playFile", "35HTGV34R7S/CD/Album/song.flac", true, 10)
  • Play a stream at volume 20 & 8s duration with snapshot/revert process to restore previous state
    fibaro.call(ID_QUICKAPP, "playStream", "https://s3.amazonaws.com/smartapp-media/sonos/bell1.mp3", true, 20, 8000)
Version 1.4.0
Tested with Sonos Sonos OS: S2 - Version 13 (number 62186220)
Tested with HC3 & HC3Lite v5.050.13 -> v5.063.30
  • Fix for Sonos firmware version 13
  • Fix for Sonos ARC getPositionInfo and malformed xmlsoap (hope full supoport soon)
  • Add playNextRadio command to navigate the radios
  • Add play mode control from QA button (loop in NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE)
  • Fix Radio metadata strange behaviors in some situations
Version 1.3.8
Tested with Sonos Sonos OS: S2 - Version 12.2.2 (number 61183220)
  • Improved support for albumArt, now work with Sonos Radio, Amazon Music, Spotify, TuneIn, Music library
  • Add option 'protect' to playFile and playStream for disallow to restart a playing
  • Add Crossfade mode support with getCrossfadeMode, setCrossfadeMode and toggleCrossfadeMode commands
  • Add sleepTimer command
  • Add setPlayMode command, support: NORMAL,REPEAT_ALL,REPEAT_ONE,SHUFFLE_NOREPEAT,SHUFFLE,SHUFFLE_REPEAT_ONE
  • Add selectLineIn command
  • Add in variables panel, "notification" variable to enable or disable the "Device notification error", if disabled QA trace the message in QA console only
  • Various improvement
Version 1.3.1 RC
Tested with Sonos Software Version: 56.0-76060 / Sonos OS: S2 - Version 12.0.5 & 12.1
  • Add support to use in block scenes (Play, Pause, Stop, Next, Prev, Set Volume, Set mute)
  • Support for album covers when available (cf. music library)
  • Performance improvement when initiating a playback
  • Improved radio playback and track information
  • Increase the number of supported radio stations (with auto configuration up to 9)
  • Support for Sonos playlists (with auto configuration up to 6 saved queues)
  • Add playFile command
  • Add playStream command
  • Add playSavedQueue command
  • Add startQueue command
  • Add clearQueue command
  • Add seek command
  • Add snapshot command
  • Add revert command
  • Add getListSavedQueues command
  • Add addURIToQueue command
  • Add checkForUpdate command
  • Add getTreble and setTreble commands
  • Add getBass and setBass commands
  • Various Bug fixes (Polling when not configured, parsing ...)
Version 1.1.1
  • Support for TuneIn "My radio stations" (with auto configuration up to 6 radios)
  • Deletion of the variable variable "isConfigured" used by internal FTI Configuration
  • Minor bug fixes (No route to host cause wrong configuration status)
  • Tested with Sonos Software Version:55.1-74250 and 56.0-76060
Version 1.0.3
  • Fix a problem with internal zoneGroups and ZoneGroupMembers parsing (Thanks to jgab, Alan Klepacz and robw)
Version 1.0.2
  • Minor bug fixes (Thanks to Macschimmi, Bodyart, minsad79)
Version 1.0.0
  • Based on my HC2 virtual Device and completely rewriten for HC3 v5.030.45 or highter
  • Very low latency and more robust device (commands execution, processing)
  • Easy installation with auto configuration assist
  • Support standard capabilities (AVTransport, RenderingControl)
  • Displaying information on the currently playing or media loaded
  • Fully controllable from the LUA scenarios (see available command list)
You can download it from the Fibaro market:
 hope you will be pleased with it
ROADMAP
  • Support for multi-devices in group used for triggering in scene and prepare for group-ungroup
  • Support for TV source (if supporteed by device)
  • Support for Group
  • Support for TTS
Edited by Krikroff
Version 1.4.0
  • Like 17
  • Thanks 2
On 8/13/2020 at 11:06 PM, Rover said:
@Krikroff
With HC2 my main use of the Sonos VD is producing Sonos sounds with mp3's for Alarm, Doorbell, etc. also with use of Sonos TTS VD.
Is the momentary version of the HC3 Sonos QA (1.1.0 referred here as 1.1.1) already capable of playing mp3 sounds? I do not need real Test To Speak.
I'd like to do the same thing. I've migrated from HC2 to HC3 & would love to play a doorbell sound through Sonos, like I could through your Sonos controller on HC2.
On 9/20/2020 at 9:35 AM, michaelash said:
On 8/14/2020 at 12:06 AM, Rover said:
@Krikroff
Please @Krikroff, could you answer this question?
This is very important for me.
Guest rafal_ll
W dniu 26.09.2020 o 10:27, Rover napisał:
Proszę @Krikroffczy mógłbyś odpowiedzieć na to pytanie?
To jest dla mnie bardzo ważne.
It is also important to me. Please
  • Hi guys! Sorry for the delay, a new version soon available (in review on market).
    RELEASE NOTES
    Version 1.3.1 RC
    • Add seek command
    • Like 4
    Krikroff!!
    Thanks for the update! Really looking forward to this release!
  • QA now available to download from marketplace :)
    • Thanks 2
    Krikoff - Thank you so much!!!
    The updated functionality was exactly what I've been looking for - My doorbell now plays a sound in three Sonos zones!
    It was also so much easier to set up than on my old HC2.
    For anyone interested here's a screenshot of the new scene using Kirkoff's Quick App.
    If anyone of you has an idea how I get the icons displayed in the app, I have stored them in the HC3 and are also displayed
    When the doorbell sound interrupts playing music, is this music continuing with the same own volume level after playing the doorbell?
    Yes, it does!
    set QA iconId variable with the desired icon ID.
    Krikroff thanks,
    Quick app works fine.
    Is it possible to play sound (mp3) from google drive?
    I tryed to make with lua a scene. I get no sound on sonos Play1.
    Who can help me further?
  • Hi, files must be in your Sonos music library, could you try with playStream ?
    @Krikroff
    Super update! Much easier to use than the similar functionality in the HC2.
    But are seeing one issue, not sure what it is related to:
    Are using the "playFile" function to play a mp3 file stored on a NAS when someone presses the doorbell button. This works just fine and I have the sound played in three different Sonos speakers in the house. But if the doorbell button are pressed several times a strange thing happened, the sound is played several time as it should, and then there is a 5-10 silence after that last play of the sound and then the last 1-2 seconds of the sound is played again in all three speakers
  • @JcBorgs, in next release: New option 'protect' to playFile and playStream for disallow to restart a playing
    @Krikroff
    I trying playStream --> not working.  Also with link MP3 from Synology NAS.
    fibaro.call(558"playStream""http://gofile.me/3k0Fd/ZnfTuVmq8, true, 50, 1400)
    I'm getting error [14.10.2020] [11:32:15] [ERROR] [SCENE206]: (load):1: unfinished string near
    What do i wrong?
    Thanks.
  • Perhaps with a " to close the uri string ;)
    @KrikroffThanks for a great QA. Forgive me if this is already covered, but didn't find it mentioned.
    I have several zones where I vary how I group them (in the Sonos app). Now, I try to create a scene where a radio channel is played on 2 of the zones, indepenent of how they originally were grouped (or not) in the Sonos app. Tried the actions:
    fibaro.call({[1] = 37, [2] = 38, }, "setVolume"10"MASTER")
    fibaro.call({[1] = 37, [2] = 38, }, "playRadio"3)
    but the problem is that they are launched as individual streams and not as one stream, hence the streams are not in sync.
    Is there any way to define a group and "playRadio" as one? If not, would be a neat feature ?
