Calendar info, Sweden.. and other countries
jgab
Sorry, this is mostly useful for Swedish users. Simple QA that sets a variable if it's a working day or not (i.e. bank holidays). Uses the api from dryg.net.
Good to have to control some automation - avoid turning on the lamps too early on a non-working day...
Code example with creating global variables and an update loop that runs every midnight and survives daylight savings....
Variables set:
"Namnsdag" - Name(s) of the day
"Flaggdag" - if flag dat - reason for flagging
"Arbetsfri" - "Ja"/"Nej"
  • 39 minutes ago, michal85pl said:
    A great idea, I hope that someone will be able to adapt to the Polish calendar.
    The trick is to find someone that publish an API without charging for it... :-)
    Hi @jgab,
    What made you decide to use global variable instead of local QA variables?
    Great!!
    Something like this?
    1000 free requests/ month
    //Sjakie
  • 43 minutes ago, Bodyart said:
    Hi @jgab,
    Because block scenes can trigger on or check globals. Easier for other scenes/QAs to get value also.
    quickVars are best for QA’s own use and config parameters.
     Well, I had introduced a bug so the QA didn't update...
    Here is a corrected version
  • Ok, bad topic of the thread (not only for Sweden now) but here is a more international version using the
    service that @Sjakie pointed at.
    You will manage the free tier as it calls the api once a day, ~30 times a month, and it's free for 1000/month.
    quickAppVariables:
    'api_key' - the api key you get when you register
    'country' - country code according to their api
    'language' - only if you pay you get the data in your language of choice - otherwise english
    'weekends' - if set to "no" will not consider weekends as work free days (default is yes)
    This behaves a bit different. The QA is of type binarySwitch and will be on when it's a holiday (or weekend) and off when not (when it's a work day)
    This way it's easy to test if the QA is on or off.
    It also supports turnOn and turnOff commands to override the automatic setting. If you wake up in the morning and decides it should be holiday anyway... :-)
    Feel free to improve.
    • Thanks 3
    Jan,
    You are the best with your service excellence!!
    Thanks for your support to all users off Fibaro.
    I cant wait to buy my HC3 but with pain because HC2 is running very smooth now, she knows it!
    //Sjakie
    Hi @michal85pl have you thought of using a Google Calendar? You could set your own public holidays and personal holidays. You could then use www.ijpuk.com service to read your calendar. You’ll have much more control.
  • Yes, but the idea was that I was too lazy to remember and setup holidays so I wanted a source to do it automatically. :-)
    However, one can subscribe to public holidays for calendars so that could be a way.
    I have already made a iCalendar QA (works with Google calendar and Apple's iOS calendar)
    but the use-case is a bit different (I guess similar to your service?). There you can add events in the calendar that will be posted as custom-events for the HC3 so that block-scenes and scenes easily can trigger on the events starting and stopping.
    I'm currently re-working the QA a bit and will re-post it as I have got some more ideas...
