Bose SoundTouch 20 QuickApp
Renaixsence
Hi, I already found lots of LUA scripts and other "inserts" for Bose Soundtouch but I can't find anything that works on HC3.
Is someone already working on a QuickApp or some kind of VD for the Bose Soundtouch ?
I don't have the proper skills to make something myself :-(  and I would love to integrate my Bose ….
Thank you
  • 9 months later...
  • 1 month later...
hi,
i  translated the bose VD to a Quick App for the HC3.
can you test it? im sure there are some bugs.
the variables are:
ipa:  the ip address of you bose device
porta: the port = 8090
names: you can set a name for the device
stat:  power status, 0=off, 1=on
updateinterval: the refreshingtime in msek.
F1, F2, F3, F4, F5, F6: you can set names for the favorites
best regards, Andy
sorry, ?i posted the wrong file yesterday (10.5.2021).
this is the right file
Edited by Andy2655
  • Like 3
Hi @Andy2655, I just download it and do a simple test with the basic buttons and works fine!!!!!
I'll do more test in the next days but it looks very promising. Thks a lot for your contribution! ☺️
  • 1 month later...
Edited by KaWi
  • 11 months later...
is not working, port 8090 refuse connection
any solutions?
thanks.
type  http://your bose soundtouch ip:8090/info in your browser. you should get an xml response from your bose soundtouch.
it works only with bose soundtouch 10, 20, 30, 300.
HC3 and bose soundtouch must be in the same network
reboot your HC3, router and bose soundtouch
update you HC3 to 5.111.48 (beta)
