Hi All,
Please guide me to right way to get args in scene on HC3
HC2 code to get scene args was:
    local args = fibaro:args()
on HC3 it not working now :(
Tried:
    local args = fibaro.args()    -> got error:  attempt to call a nil value (field 'args')
    local args = fibaro:args().   -> got error: attempt to call a nil value (method 'args')
LUA editor don't show any functions containing "args"....
Help, please...
Is not yet available at the moment
  • 9 months later...
Is this still not possible?
A lot of my HC2 scenes use arguments to pass from one to another scene.
Is there an alternative?
The alternative is to write the scenes as QAs.
If the scene was a "shared function" like Logging scene or Message scene it is best replaced by a QA.
QAs can react to fibaro.call(<QA_ID>,<action>,<args...>) so it makes them very convenient to carry out shared functionality.
If you scene also triggered on devices etc it's a bit more work in a QA, but there are lots of examples in the forum how to poll for events within a QA.
The other problem is that QA's can't return values (fibaro.call doesn't return values), but that was kind of a problem with scenes to. However there are ways around that too with some coding,
Yep, working great!
Thanks!
So why does that work from another QA and not from a scene?
The arguments don't get passed on, but the QA method gets called, just the arguments are empty.
It should work. How does your call look like?
(There are some strange marshaling going on for some types but there are ways around that too...)
QA device type is generic.
The same as in my other QA call:
And in the QA the method looks like
Edited by SDeath
Well, that's the kind of string arguments you can't send. The way they encode the api.call from the scene to the QA makes them interpret them as key/values of the api.call...
The QA implementation of fibaro.call is better (don't ask me why they have different implementations)
The way around it is probably to url encode the string. Unfortunately urlencode is not built-in...
on the other hand I can think that it's strange that the caller of Pushoverleaf needs to put together the url to pushover as the argument.
Alternatively create the url in the QA
Yes you are correct, I should put the link together in the QA, I will change the code, it looks cleaner.
Thanks for your help!
Quote
Works great!
...but it is an issue that they fail encoding the parameters correctly from the scene's implementation. If you are unlucky and an argument string has the wrong format you get unexplainable bugs...
Yes true because I saw no error in the LUA itself, just the response from the Pushover API that there was no message.
  • 2 years later...
On 5/17/2020 at 12:43 AM, afendikov said:
Tried:
After more than 3 years still not available. Lame Fibaro! :-(
You can send customEvents, but they don't carry any arguments, so you need a lot... :-)
Seriously, Scenes on the HC3 are useless for serious stuff - QAs have taken over that role - and you get (at least one way) function calls to declared QuickApp functions.
The triggers you get in Scenes are easily implemented in QAs and you get much more flexibility (you can trigger on more types of events).
You can have one QA that collects events/triggers and send to your other QAs for efficiency.
Scenes seems to be for simple no-code integrators...
Hi @jgab ,
Thank you for the tip! Last few days I was busy comparing HC2 and HC3 and how much effort and time I will need to invest to move my UHAS to HC3. At this point it seems lots of time and effort. Also, I fear that at some point of development Fibaro will do some drastic change that will require to do few steps back and already existing code rewrite to either make it working or to get advantage of those changes. Provided manuals are maybe OK for making some simple code and not for advanced developers. Not to mention, that probably many things are not even mentioned in those manuals and will depend on on yours and some other gurus findings to be able to do some advanced programming. History repeats itself and I'm still not sure that I want to do it all over again.
4 minutes ago, Sankotronic said:
Hi @jgab ,
So I moved ER3 from HC2 to ER4 on HC3, ~4000 lines of code and it was straight forward to move most of the stuff. On the HC2 I had to do some acrobatics to get triggers without restarting the scene, but that is of course trivial on the HC3 with QAs. I believe your biggest hurdle will be the QA UIs that you obviously spent a lot of time on with the HC2 VDs. The binding of functionality to UI elements are of course different for QAs vs VDs.
I wouldn't worry about Fibaro making changes - they move slower than tectonic plates...
There are advantages and I find the HC3/QA environment a huge improvement over HC2 (but not perfect  - seems like Fibaro always stops before perfect)
- you can have lua files you reuse between QAs, and there is more or less efficient ways to call functions between QAs.
...if you embark on this journey I would recommend to develop the QAs offline, using something like ZeroBraneStudio and TQAE or vscode and fibemu (what I'm using currently).
Gives you debugging, testing multiple QAs simultaneously for testing interactions, and a build and deploy system for multi-file QAs (makes it easy to build up your own shared libraries).
It will cut your development time with more than 50%...
...just saying...
Hi @jgab ,
Thanks for encouragement and for sharing your knowledge here on forum. 🙏 Will start with learning and planing.
So, I took a look at a VD (was a long time ago) and it was your LIFX_Color_VD_v1.4.vfib...
Besides your, not so small, task to migrate to HC3, this may be of interests to others moving VDs
It's doable to auto convert the UI layout.
I wrote a small program that took the fib and created a QuickApp file with the headers for my fibemu emulator
The --%u=... declares the UI element and builds the correct structure for a QuickApps viewLayout incl. Lua handlers.
The mainLoop is here just included in the QuickApp:onInit() function and some simple transformation of the code us done ex. fibaro:* to fibaro.*
Here I also ignore the lua code for the UI elements (buttons and sliders). One approach is to stuff them in a separate QA file and create QuickApp:<btn/sliders> functions to call them.
However, taking a step back one realises that the code needs some refactoring.
  • There are a lot of library/common functions that should be put in a separate QA file and reused between QAs
  • Most of mainLoop should not be put inside QuickApp:onInit() but outside.
    :onInit() should be just initialisation and maybe a setInterval to run a periodic loop
  • The code for handlers for the UI elements could be reduced as they don't need to include a lot of support functions and could focus on their tasks. Probably would not need to be put in separate QA files, but kept as QuickApp:* functions in the main QA file.
Probably, some more steps could be automated by the transformation program, but ultimately their will be a lot of manual tweaking to make it QuickAppy...
Hi @jgab ,
Thanks for trying. I think that converting HC2 virtual devices to HC3 quick apps is not easy, specially because VD's are not that advanced as QD. You can use my Sonos API Player VD and Sonos API Player QA and see all the differences. On HC2 I was able to use predefined global variables to store data tables while on HC3 predefined variables can't hold any other data but the one that is initially predefined. That means that code that takes care for global variables must be changed.
Another thing that I need is to be able to store my own role types to QD so that they can find each other including scenes. On HC2 I was able to use scene json table to store this in "properties" as a table together with scene version and run type. For virtual devices I had to use global variable. Fibaro provided Role is just not sufficient for me since there are some combinations of roles that can't be covered with their solution. I'm now checking possibilities on HC3 with swagger to see if situation is a bit better with QD's and scenes.
Also, there are some solutions on HC2 that required combination of virtual devices and scenes while on HC3 those solutions can be achieved solely with QD's. One example is Philips HUE with new API2 which requires HTTPS calls so all communication between HC2 and Philips HUE bridge I had to move to scene, but on HC3 this can be done with QD. Problem that I'm facing with HC3 and QD child devices are that child devices are rudimentary which is not good enough from my perspective. This is because I want to have possibility to select and activate HUE light scenes at least on group of lights as I have made it for HC2 UHAS. I need that so that users can adjust lighting for specific situation and then save that setting to be used in light automation. This means that When user add QD children for HUE grouped lights then there should be besides default buttons and sliders also buttons and labels to select desired HUE light scene and activation.
But of course you know all the above. :-) I think I will manage, specially thanks to your effort and knowledge shared here on forum. Without your help and your posts here on forum everything would be much more difficult. Eternal thanks and respect goes to you Jan! 🙏
