HC3: ring doorbell
10der
  • 11 hours ago, SvenG. said:
    can't get the new version to work
    Any errors welcome
    photo? "" / devices / 1818 / action / sendPhoto "
    Telegram
    Hallo Oleg, your new QA "Ring_doorbell_v21-21-21.fqa" i must have:
    EMAIL: Ring-EMail
    PASSWORD: Ring-PW
    OTP: ??? (in old QA Ring_doorbell_v5.fqai become automatic)
    access_token: ??? (in old QA Ring_doorbell_v5.fqa i become automatic, but i cant see)
    hardware_id: ??? Where i become this?
    please help me...Gruß Sven
  • Fill email and password account
    that’s all no other fields
    save
    press button get OTP code
    Edit otp code var with sms code
    save
    it should start without any issue
    done
    OK i have found the error. When you install QA you have five fields under variables: EMAIL, PASSWORD, OTP, access_token, hardware_id. All five fields filled with a "-". You must fill field EMAIL and PASSWORD, OTP can stay with "-" but the fields "access_token"and "hardware_id" must be delete before you press OTP-token. Now you become a SMS with OTP code. Now delete behind OTP code the "-" and fill with the numbers out from SMS
    Hallo Oleg, have next question. The device ID in Scene...what device is it?
  • My TG chat ID ;) deviceId is my phone telegram chat I’d ;)
    good morning...thx, but I had already figured that out. It's the same number as for:
    local groups = {
        ring = {"15011xxxxxx"}, <----------------this ?
        motion = {"3333333333", "4444444444"}
    When i ring the bell, then trigger the scene and send the picture to my telegram onto handy, but when i start scene manual (user) then become i the error:
    [23.01.2021] [10:29:49] [DEBUG] [SCENE273]: sourceTrigger {"type":"user","id":2,"property":"execute"}
    [23.01.2021] [10:29:49] [ERROR] [SCENE273]: /opt/fibaro/lua_engine/lua/lib/json.lua:185: unexpected character '' at line 1 col 1
    but I am very happy that you are trying so hard here and helping everyone so ... thank you
    Edited by SvenG.
  • 47 minutes ago, SvenG. said:
    local groups = {
    yes, events by motion want to see my old dau and i. but about ding-dong all family
    local event = json.decode(fibaro.getValue(2051"userDescription"))
    2051 is a motion sensor.... try ding dong
    thx now the testfunction run too :)
    Edited by SvenG.
    Hi.
    Can this Ring Door Bell feed be sent to a chromecast device as well (to play on the TV or google home display)???
    using a Home Center 3 (newbie)
    wayne
    Edited by wayne1111
  • QA can send screenshot of ding-dong and motion events as event into HC3 event system.
    if you have experience how to display this PNG file on TV or Google Home - welcome.
    not i can see screenshort / picture on my TV via KODI.
    so when motion occurred or ring button is pressed I can see in the right corner of TV popup pic of event.
    • 3 months later...
    Hi @SvenG.
    As the creator, 10der, no longer has his active profile here (THIS PROFILE DEACTIVATED! ), would you have any details on how you were able to activate this QA?
    I followed what you wrote but despite that nothing happens.
    Thank you
    just fill email and password
    than fill OTP token.
    Hey good news, @10der is there ;-)
    ok, this is what i did, and now the OTP variable is still on "-" however the "hardware_id" variable has a code entered. is it correct ?
    I never received the OTP code
    I created a scene, which works when I test it, but nothing happens when I press the doorbell button. As if nothing was detected. Where is the error?
    Log error :
    [30.04.2021] [12:20:09] [TRACE] [QUICKAPP141]: UIEvent: {"values":[],"elementName":"OTP_Token","deviceId":141,"eventType":"onReleased"}
    [30.04.2021] [12:20:09] [DEBUG] [QUICKAPP141]: Request initialization OTP token...
    [30.04.2021] [12:20:09] [DEBUG] [QUICKAPP141]: Wrong status '401' in response!
    [30.04.2021] [12:20:09] [ERROR] [QUICKAPP141]: OTP result: ERR.
    Edited by JLT007
    ok i understand there is no workaround for this problem.
    I delete this "Quick App" Ring from the HC3.
    and use IFTTT which works great and easily with Ring for me.
    Thank you
    • 2 months later...
    Guest Andrew Riley
    Hi Team
    Great work on this plugin @10der
    I'm still having trouble getting mine to work.
    I've tried the above steps including the 'delete' "access_token"and "hardware_id" variable before running the OTP button. I've tried a bunch of combinations but I consistently get the below "Wrong status '406' in response!
    " error.
    [04.07.2021] [20:57:19] [DEBUG] [QUICKAPP142]: RingDoorbellButton init
    [04.07.2021] [20:57:19] [WARNING] [QUICKAPP142]: Variable hardware_id not found
    [04.07.2021] [20:57:19] [WARNING] [QUICKAPP142]: hardware_id initialized!
    [04.07.2021] [20:57:19] [WARNING] [QUICKAPP142]: Variable access_token not found
    [04.07.2021] [20:57:19] [WARNING] [QUICKAPP142]: Please, request OTP token for authorisation.
    [04.07.2021] [20:57:19] [DEBUG] [QUICKAPP142]: onAction: {"args":["OTP","-"],"deviceId":142,"actionName":"setVariable"}
    [04.07.2021] [20:57:38] [TRACE] [QUICKAPP142]: UIEvent: {"values":[],"eventType":"onReleased","deviceId":142,"elementName":"OTP_Token"}
    [04.07.2021] [20:57:38] [DEBUG] [QUICKAPP142]: Request initialization OTP token...
    [04.07.2021] [20:57:38] [DEBUG] [QUICKAPP142]: Wrong status '406' in response!
    [04.07.2021] [20:57:38] [ERROR] [QUICKAPP142]: OTP result: ERR. { ["data"] =
    Running on a new HC3 5.070.42.
    Have tested logging into Ring.com via the browser and the OTP works (like a normal use login)
    Any suggestions?
    Many thanks.
    Andrew
    hallo together hallo @10der i have same problem. I think ring have made an update ? Oleg u can help us?
    thx Sven
    thx Sven
    ok.
    @SvenG.this QA works on my naked ? HC3 24/7
    PS: please do not ask me anything about Z-wave. my HC3 now naked. only QA with zigbee + some QA device like ring.
