julkobg 0
Hi All,
After rearranging some modules in my home I am not able to pair a Dimmer 2 module again. The new set up is 2-wire set up. I followed the instructions for reseting the module through B-button (even tried with Reconfiguration from my HC2 before removing it from the controller). When I press and hold the B-button there is now indication for reseting or entering the menu. Only stay green lough is on.
I removed it from HC2 without following the instruction for "Removing (Exclusion)" from the Z-wave network, but as I said I was not able to bring the pairing state by holding B-button.
I tried pressing B-button 3 times or switching no/off 3 times S1 when HC2 is in adding mode to pair it again, but no success.
No meter what I do the lights are aways on (14x5W led lights GU10), green led light is on, not letting me to reset ot pair again.
1 answer to this question
