FGBS-222 - Smart Implant - Parameter 20 fehlt
AlexK88
Hallo,
ich habe den Fibaro Implant inkludiert. Nun habe ich 2 analoge Sensoren angeschlossen und möchte die Parameter 20 ändern. Diese kann ich aber nirgends finden. Woran kann das liegen?
Vielen Dank
Alex
4 answers to this question
Hallo @AlexK88
Einige der noch existierenden Parameter sind nicht in den Vorgabe endhalten.
Dann musst du den Haken bei "Vorlage für Parameter verwenden" rausnehmen und den Parameter einfügen. Danach kannst du dann den Parameter einstellen.
Hier wird dir kaum einer auf Deutsch antworten da das hier ein Englischsprachiges Forum ist.
Versuche es bei
 das ist ein Deutsches Forum.
Some of the parameters that still exist are not included in the specification.
Then you have to uncheck "Use template for parameters" and insert the parameter. Then you can then set the parameter.
Hardly anyone will answer you in German here as this is an English-language forum.
Edited by FBerges
Select the  smart implant from the list of many devices that were installed when you included it. Parameter 20 and 21 are the Local Protection buttons in the advanced tab.
  • Hello, thanks for fast reply. I used a ds18b20 sensor and then the options were visible. I think, that the analogue sensors are not working. Now I see the temperature I want to see.
    The Problem is now, that I want to connect a second ds18b20. If I connect 2 sensors with the same cable length (3m), all is working. Now I have a cable (10m) between the Fibaro Implant and one of the ds18b20. If I connect one of the ds18b20 at a time, it is working, too. If I connect both sensors at a time with different cable lengths it is not working. Both Sensors are not working.
    Is there a Problem with the impedancy because of the different cable lengths?
    Thank you for helping.
    As per smart implant manual :
    Do not connect other sensors than DS18B20 or DHT22 to SP and SD terminals,
    Do not connect sensors to SP and SD terminals with wires longer than 3 meters,
