Z-Wave routing is a blessing and a curse... And more of a curse when you get "long routes", which are often defined as 3 and 4 hop routes (that is the longest route possible).
I regularly point out to users... When you use a Zniffer to capture routes, it is very likely you won't see the complete conversation.
Why is that? Because it stands to reason, the node is far away and the hops are necessary to get there so that would mean wherever you place your Zniffer, it won't b
