First time user HC3
  • I'm just afraid that it is to advanced for me because i'm not a programmer, and block scenes is more my thing. And nothing works now that I switched to hc3, so hopefully after reading up here in the forum i can learn to use it properly.
    Guest Freddan67
    What is your problem ?. Tell us we'll see if we can help you with anything.
  • I got all components registered on the hc, and make scenes, but the 2-channel scene button is not working. And it doesn't seem to be a function to if you can see when a switch is activated, as it was in hcLite.
    I've got 2x scene-switches, and both are registeret, but will not work when activated.
    Also 1 dimmer switch worked for some hours, but now has no connection, but the dimmer works manually. I deleted it, and now i can't reconnect it.
    I am seriously considering connecting hcLite back up, since i've got that working on the first try...
    Guest Freddan67
    What is it? I had something similar with fibaro keyfob. A factory reset and then they worked, give it a try
    Try again the "remove device" function of the dimmer in the HC3.
    Even it's not included, you can do an exclusion at all time.
    Maybe it didn't do a proper exclusion.
    Then include again.
    Edited by Flash
