Smart Module/ Double Smart Module
andrespadron92
Hello everyone, I was wondering how can i control a 24 VAC valve using a Smart Module or another Fibaro Device. I  used to install a Relay Switch  to control this kind of valves, but now, when i read the techical description of Smart Module i can find this sentence
"Always use the same power source for L and IN terminals"
How can i control 24 VAC Valves?
Thanks.
Hi can someone from Fibaro like @T.Konopka comment on why the instructions say "Always use the same power source for L and IN terminals" ? this is a big limitation as it forces us to append a secondary relay and it's really difficult to understand since the device has separate connectors for L and IN... will you make an updated version without this limitation given that FGS-222 seems not to be available anymore?
Riccardo
Edited by RiccardoCanetta
  • 1 year later...
W dniu 17.06.2020 o 16:07, Andrés Padrón napisał:
Hello. I have found a way to control 24 VAC sprinklers valves with Double Switch and Solid State Relay SSR-40AA.
Check Out this video.
Regards.
Hey @Andrés Padrón, can you draw a schema of your solution, I am looking for the same :) I have double smart module, but specification is very similar as far as I remember.
