CPU load API values meaning
cincura.net
The REST API documentation says the values in `cpuLoad` are percent in user/system/idle. But when I check the API, the values do not look like a percent at all.
What is the unit? Can somebody shed some light on it?
Some calculation require to get actual CPU load in %
May be that could help ( code from @AutoFrank
 scene)
-- CPU
  local cpu0_puser      = tonumber(response.cpuLoad[1].cpu0.user)
  local cpu1_puser      = tonumber(response.cpuLoad[2].cpu1.user)
  local cpu0_pnice      = tonumber(response.cpuLoad[1].cpu0.nice)
  local cpu1_pnice      = tonumber(response.cpuLoad[2].cpu1.nice)
  local cpu0_psystem    = tonumber(response.cpuLoad[1].cpu0.system)
  local cpu1_psystem    = tonumber(response.cpuLoad[2].cpu1.system)
  local cpu0_pidle      = tonumber(response.cpuLoad[1].cpu0.idle)
  local cpu1_pidle      = tonumber(response.cpuLoad[2].cpu1.idle)
  local cpu0_PREVTOTAL  = (cpu0_puser + cpu0_pnice + cpu0_psystem + cpu0_pidle)
  local cpu1_PREVTOTAL  = (cpu1_puser + cpu1_pnice + cpu1_psystem + cpu1_pidle)
  fibaro:sleep(1000)
  response1, returnCode = api.get("/diagnostics")
  local cpu0_user       = tonumber(response1.cpuLoad[1].cpu0.user)
  local cpu1_user       = tonumber(response1.cpuLoad[2].cpu1.user)
  local cpu0_nice       = tonumber(response1.cpuLoad[1].cpu0.nice)
  local cpu1_nice       = tonumber(response1.cpuLoad[2].cpu1.nice)
  local cpu0_system     = tonumber(response1.cpuLoad[1].cpu0.system)
  local cpu1_system     = tonumber(response1.cpuLoad[2].cpu1.system)
  local cpu0_idle       = tonumber(response1.cpuLoad[1].cpu0.idle)
  local cpu1_idle       = tonumber(response1.cpuLoad[2].cpu1.idle)
  local cpu0_TOTAL      = (cpu0_user + cpu0_nice + cpu0_system + cpu0_idle)
  local cpu1_TOTAL      = (cpu1_user + cpu1_nice + cpu1_system + cpu1_idle)
  local cpu0_Percentage = ( ( (cpu0_TOTAL - cpu0_PREVTOTAL) - (cpu0_idle - cpu0_pidle) ) / (cpu0_TOTAL - cpu0_PREVTOTAL) ) * 100
  local cpu1_Percentage = ( ( (cpu1_TOTAL - cpu1_PREVTOTAL) - (cpu1_idle - cpu1_pidle) ) / (cpu1_TOTAL - cpu1_PREVTOTAL) ) * 100
  cpu0_Percentage = round(cpu0_Percentage)
  cpu1_Percentage = round(cpu1_Percentage)
 scene)
-- CPU
  fibaro:sleep(1000)
These calculations look strange... isn't nice a part of user? It's usually 0 on the HC3 but anyway... and doesn't the percentage calculation always return 100?  sorry, didn't see the 'p' prefix of idle the variables.. but should nice be included?
