Automatic Lightning System for HC3 (Motion/Average Lux)
chiel-s
  • 11 hours ago, 10der said:
    can you forgot for this feature? i am said about fxxxxxing profiles?
    just add a global var
    override = "WorkRoomLED",
    @10der, when I use:
    and global variable is set to off:
    The lights are turned on.... Doesn't seem to work.  Or did I understand it wrong?
    Cheers,
    Chiel
    Edited by chiel-s
  • 27 minutes ago, 10der said:
    uppercased please
    off != OFF
    Sorry...thanks! :-)  Working now ?
    • 1 month later...
    On 9/12/2020 at 10:03 AM, chiel-s said:
    Ehm yes. Is it working in combination with your QA @petrkl12? (
    In that case I will give it a try ;-)
    For me was the combination with Hue (using the QA of @petrkl12) also not working. Color was setting fine but brightness was always 100%. I changed line 278 of the main code :
    Hope it helps others with Hue lights.
    Edited by impact
    On 3/6/2021 at 7:14 PM, petrkl12 said:
    I have added "setBrightness" to next version of Hue lights
    @petrkl12 Vyborny, dekuji moc! Really like your QA and it works excellent! Hesky vecer!
    Edited by impact
    @petrkl12 Just a small remark, at line 277 I changed the order of setting color and brightness of the Hue light. Otherwise it first flashes bright in night if previous brightness was higher. The color change is than a little delayed, but almost not mentioned.
    Quote
                    if #color == 5 then
                        --fibaro.call(id, "setBrightness", color[5]) --RGBW??
                        fibaro.call(id, "setValue", color[5]) --Hue
                    fibaro.call(id, "setColor", r, g, b, w)
              --   Changed order of setting color and brightness, first brightness than color > otherwise light flashes bright
    • 5 weeks later...
    My question will hit the top 10 of most stupid questions of all time, but I'm firing it anyway.
    I'm very interested in the script you guys are talking about. I've got a HC3, multiple motions sensors and multiple dimmers etc and looking for a script like this.
    But am I able to download this soemwher, because I noticed that (a lot of) changes are made to it?
    Cheers,
    Jan
    • 3 months later...
    Guest Benrive
    Hi, U used the first LUA for @chiel-s.
    I only one sensor lux , i think this error it's for de same.
    In second script i hace the following error but ,I can't find how to solve it.
    In the first scene to the averageLux , debuf tag for media lux it's 211.0
    [SCENE15]: (load):24: attempt to concatenate a nil value (local 'localLuxAverageRoom')
    Edited by Benrive
    24 minutes ago, SmartHomeEddy said:
    Looks like an average is not calculated, because you have only one Lux sensor.
    Without reading the whole topic, since i am not that far in setting up the system.
    I use the sunpower value of the quickapp you made as a second value to
    turn on the light in daytime. These days it sometimes gets a little dark in
    the living room, because of the bad wheather. So, when the  value of the inhouse sensor
    is < 200. The lights turn on. And when the sunpower value is > 150 and the normal sensor is > 500. The lights turn of.
    Probably a very simple solution, but
    This actually works perfect :)
    Edited by ppeterr
    1 hour ago, Benrive said:
    Can you share how you have done it?
    I made this only for the daytime, when it gets a little dark outside.
    Its not anything special :) But here it is. I assume you can make a block scene
    that turns on the light when it is below a certain lux value. For that i use a normal
    lux sensor. Turning the lights of when its not needed anymore, i use the "light power"
    value from the Buienradar Weather app that @SmartHomeEddy made. (only for europe i think)
    That gives me values (like: the sun is shining) from a wheather station wich is about 15mins from my home.
    4 blocks on the left.
    the first checks if the light level inside the house is > 500 lux
    the second checks the value from the sunpower outside > 150
    the 3th checks if the lamp is atually on
    the 4th is the daytime setting.
    2 blocks on the right (action if all true)
    1st - turn the lights of
    2nd - Let my echo show in the living room say "i turned the lights of"
    Edited by ppeterr
    Guest Benrive
    If that one also suits my need better, I will try to use it and if I have a problem I will discuss it with everyone.
    Thanks a lot
    Thanks a lot
    Where are your from if i may ask, because i think the buienradar quickapp is limited to europe.
    (Buitenradar Weather measures data within the Netherlands)
