display sunset time
ErnstH
Hi all,
I would like to display a debug message with the time of sunset + an x amount of minutes. So there needs to be a calculation.
I have a few scenes whose start is dependent of the month, turning lights on earlier or later.
My debug message should be something like "today lights will be on at 21:15". That 21:15 is the calculated time.
I have these declarations at the start of scenes:
local sunsettime    = fibaro:getGlobalValue("SunsetTime");
local sunsetHour   = fibaro:getValue(1,'sunsetHour')
But I can't figure out how to do this. Shouldn't be very complicated, but i'm not good in LUA programming with time.
Hope someone can help me out.
1 hour ago, theuksbest said:
Is it not possible then to just have the current variable showing here, rather than a current report on all of them?
you can't wrote a single line on LUA?
right yeah?
/monthly_2020_11/image.png.2de4e24ed7d9943ea7c20d0a373cbedd.png" />
No sorry i'm a beginner, i can't really read or write LAU code except maybe some of the more simple logic.
ok thanks for your help, I think what i have understood is it should be logging all of those as events now. However, i couldnt select from a block scene, any of the events. I just get a question mark when i hover the mouse over the Change box?
not sure where i'm going wrong with this
Events is only for pre-defined custom events  (General/Events)
...and I don't think that @10der's QA define and emit those.... maybe a good idea?
just a moment
i have idea
13 minutes ago, 10der said:
just a moment
i have idea
/monthly_2020_11/2f3118e536764d9baa92df373a90559a--husker-du-var.jpg.b32426175e586fe6dd98fd98c261b75c.jpg" />
oops! :(
blocks can`t implement what I want... sorry.
vice versa
to globals - simple value
for advanced users
local value = json.decode(fibaro.getValue(1639"userDescription"))
here is json with details
@10der ok... so installed the new QA and seems all working, and I can see in the global Variable the DayPart single event perfectly like you have above. However, I still can't seem to use it as a trigger in a scene, it's just not triggering - I'm sure this is just me not fully understanding how this works, but hoping you could point me in the right direction again;
I cant see why this isn't working..? (id 274 is just a door/window sensor to make sure the window is closed)
If I run the scene manually it works fine, so it's just getting the trigger working
any ideas?
IMHO sunset is uppercase should be
Idk what fibaro devs developed but in global QA set value with uppercase
why is not triggered? Idk
i have a bad skills right now in HC3 scenes
sometimes hc3 look like crazy cuz
sometimes is not triggered
sometimes has wrong behavior as for me
and  ? on the ? sometime calling params wrong with calling params and order params with QA
so, what I can recommend- RTFM
but i can 1000500% says what this demo works
left
  conditions = {
            id = 1639,
            isTrigger = true,
            operator = "!=",
            property = "userDescription",
            type = "device",
            value = ""
  operator = "any"
right
if sourceTrigger.property == "userDescription" then
    local event = json.decode(sourceTrigger.value)
    print("EVENT ", event.dayPart, " is OCCURED")
/monthly_2020_12/image.png.1438f55bf884665947962a0a309cb510.png" />
/monthly_2020_12/image.png.daf250fcd44b1e14a5f9ddda52c08f67.png" />
ok! lets seeyou at the morning!
I’ve changed to uppercase too and also set it up for the morning. Although i thought as its the weekend I’d test SUNRISEEND instead! ;) give me some extra sleep time!
Thanks for the help
On 11/21/2020 at 11:49 PM, theuksbest said:
@10der still haven't been able to get a scene to trigger properly, can you see anything obvious?
left (id 274 is just a window sensor to make sure the window is closed before the blinds close)
right
Edited by Jay Ess
