weather met.no (standalone)
10der
V1.2
/monthly_2020_08/image.png.48e6ef563ffa90101671a4e6acbcc6fd.png" />
Edited by 10der
1 answer to this question
@10der  I found your fantastic QA met.no, but I have some questions about it.
1) Does the forecast apply until the time shown in ui?
Or does the forecast apply from this time and one hour ahead?
2) Do you get local time from HC3, or do I have to configure the time based on Greenwich Mean Time?
I wonder this because I get different results when I type the address directly in a web browser.
A tip is also to change in your code from ";" to "&". See picture below from met.no.
Thanks again for an excellent QA.
/monthly_2021_02/met.no_QA.png.c257f945f9d660b3387cb0ae643c3e0d.png" />met.no_separator.png.f333a20dfafbf5d4e56de050a2b00c7d.png
