HC3 and Foscam IP camera
Arnes
Does anyone have experience with Foscam on HC3?
I do not get a picture in preview. I connect to an external ip. Do I have to use https and install SSL certificate?
I did not find the model I have so I had to use "other"
I have to use MJPG streaming and use this path http://USR:[email protected]:IP/video.cgi
Edited by Arnes
9 answers to this question
i have Foscam 9900P and do it with:
http://YOUR_IP:88/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=USER&pwd=PASSWORD
u must change:
YOUR-IP: with your IP
USER: with admin user from Cam
PASSWORD: with admin Password from Cam
Port from Cam is 88...u write it after ip with ":" so: 192.168.1.1:88
sry my english is bad :(
@A.Socha how Do you do, sir?! ;)  Are you still need repro from our side or my reports a good for understanding where is issue and how you should encode url with already exists query param
  • 12 minutes ago, 10der said:
    @SvenG. you can't do it. cam preview doesn't work. bug in UI.
    It worked! Not in web UI, but in the app it works.
    But i could not move the camera.  I tried with /cgi-bin/CGIProxy.fcgi?cmd=ptzMoveLeft but it did not move the camera.
  • @10derDo you know if HC3 will support H.264 ? My camera D2EP only support H.264.  I really need video streaming, not snapPicture
    Can you recommend a outdoor dome ip camera that support MJPEG ? As i understand video streaming with MJEPG vil be possible when they have fixed the bug? Or is it only snapPicture that will work?
    Edited by Arnes
    The ways of the Lord are inscrutable.
    I have China cam with PTZ from "ali" more than 3y. no issues. TBH
    it's noname :)
    /monthly_2020_08/image.png.d7bc7f5f09c21efd4c19d12ddec46f8f.png" />
    also it works with moving commands
    Can you tell me how you search for wifi cameras that support mjpeg? Aliexpress doesn't come up with any results.
    H264 is not supported by Hc3  right?
    it's noname :)
    Is that it an rtsp camera? Could you share the configuration? I bought a Noname as well from Ali but can't figure how to integrate it to fibaro.
    The model is XM530_R80X20-PQ_8M
