QuickApp - Buienradar Rain ⛈
SmartHomeEddy
This QuickApp predicts the rain in The Netherlands (and Belgium, a part of Germany and a small part of France and England) with data from the Buienradar, two hours in advance. The value of this QuickApp represents the minutes until rain. If there is no rain expected, the value is set to 0. If it rains, the value is set to 999 and the amount of rain (mm/h) is shown.
Buienradar updates every 5 minutes with intervals of 5 minutes until 2 hours in advance. If rain is expected within the first predicted 5 minutes or less, the QuickApp assumes it is raining.
If rain is expected or it rains, the interval for checking the Buienradar data (default without rain 300 seconds, equal to the Buienradar updates) is speed up (default 60 seconds) so the QuickApp value is updated more often.
Version 1.1 (19th March 2021)
  • Added Child Device for rainfall mm/h
  • Added Quickapp variable for debug level (1=some, 2=few, 3=all). Recommended default value is 1. debuglevel 4 = Rain expected simalation. debugLevel = 5 Raining simulation
  • Freed up some space (3 positions) in the presentation of the amount of rain
  • Increased the default value of the maximum lines (maxLines) from 23 to 26
  • Changed the unit in case of rain to empty
Version 1.0 (25th October 2020)
  • Added the possibility to change the icon according to rain, rain expected or dry. Three not mandatory quickapp variables are added to fill in with the icon number for rain, rain expected and dry.
Version 0.3 (26th September 2020)
  • Build an extra check for an incomplete Buienradar response (sometimes less than two hours)
  • Added global variable maxLines to arrange the maximum amount of lines to indicate the amount of rain (one line for every 0.10mm rain) to fit the screen of your mobile device
  • Decreased the default lines from 25 to 23 to show it right on an iPhone
Version 0.2 (4th September 2020)
  • Ready for the new Mobile App 1.9: Added visual level of rain (forecast) with thanks to @tinman from forum.fibaro.com
  • Added warning for latitude and logitude settings where Buienradar Rain has (no) coverage
Version 0.1 (15th August 2020)
  • Initial version
The value of this QuickApp is the same as the value of any other device like a temperature, humidity, CO2 sensor. With the value updated in this QuickApp, you are able to build and use your own scenes to notify, to close or open sunscreens, to close or open windows, etcetera
Or a Block Scene:
/monthly_2020_08/A9331C68-066D-46DF-9E4D-CA53F490ECEE.jpeg.904f614b55dca5b1d898d768cd467a2c.jpeg" />
Where the value:
0 = no rain expected
999  = it is raining
any other number = the minutes until rain expected
In this example rain is expected at 20:55, within 93 minutes.
Where 321 should be your Buienradar Rain device ID
In this example it is raining. In the log you can see how much it is raining:
JSON data copyright: (C)opyright Buienradar / RTL. All rights reserved.
JSON data terms: Deze feed mag vrij worden gebruikt onder voorwaarde van bronvermelding buienradar.nl inclusief een hyperlink naar
Aan de feed kunnen door gebruikers of andere personen geen rechten worden ontleend.
QuickApp variables (mandatory, they will be automatically added with the default values):
  • intervalR = Number in seconds to update the data when rain expected or raining (default is 60 seconds, must be different to IntervalD)
  • intervalD = Number in seconds to update the data when no rain expected. Buienradar is updated every 300 seconds (default is 300 seconds).
  • latitude = of your location (default is the latitude of your HC3)
  • longitude = of your location (default is the longitude of your HC3)
  • maxLines = maximum number of | to indicate the amount of rain (one line for every 0.10mm rain)
  • iconR = icon number for rain
  • iconE = icon for rain expected
  • iconD = icon number for dry
Coverage:
Latitude (50-54) / longitude (1-10)
NO or YES coverage
Download the QuickApp here (download the file and un-zip):
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
  7. Check the latitude and longitude settings in the QuickApp Variables and change them to your settings (or delete them and push the “save” button to force the right default settings)
Edited by SmartHomeEddy
  • Like 4
Hi @SmartHomeEddy,
Thanks for this Quickapp, i find it very useful!!
Can you give me a hint how to use the "rain value" in other scripts on my HC 3.
as it is my first QuickApp i dont know how get the value of the quick App to other scripts.
maybe there is a way to set a global variable in HC3 to use this value in a central way ?
  • @pblacky You can use the QuickApp like any other device that has a value that is important to you, like for example a temperature, CO2, Lux, PM2.5 or humidity sensor.
    With this Lua code you can get the actual value of the Quickapp:
    321 is an example, should be the device number of your QuickApp Buienradar Rain
    Where the value:
    999  = it is raining
    An example of a short Lua script (action part):
    Where 321 should be the ID of your QuickApp Buienradar Rain and 28 should be the ID where you want to send the notification to.
    In the declaration part you have to set the condition when you want to get the notification. But you could also leave that blank and set the script to manual and give it a push from your mobile app just to know if it is going to rain within the next two hours.
    /monthly_2020_08/5A9E2B7E-1432-44FF-8A46-BD5C98BF40E0.jpeg.771002712496804ebefd785e778d2cae.jpeg" />
    To get the text under the value, use:
    Where 321 should be the ID of your QuickApp Buienradar Rain.
    Ofcourse you can also use the block scene. You can select the QuickApp as any other Device and set a condition (value) to let the block scene “do something”. For example if value = 999, then it wil be raining. Or that is maybe too late ?. Than for example > 0 and < 999 then rain is expected within 2 hours. Or set the <999 lower for finetuning within how many minutes rain is expected. I don’t recommend to set an exact value, because the prediction can go from 15 minutes to 5 minutes and if you set a condition on exact 10 minutes, you will get wet?. So alway give it some space with a value between.
    Remember the prediction can go from rain to no rain up and down. It is still a prediction. That can give several notification, or close and open sunscreens, etc. It still depends on how certain it is, that it is going to rain.
    Here is an example Lua script intended to run manually, to get informed about the rain expectations:
    Many thanks @
    For your detailed explanation!
    I'm currently working on a code to integrate your Buienradar Rain into my CronJob script.
    If something useful comes out, I'll genetically share it here ;-)
  • Great weater conditions in Europe to work with Buienradar Rain ? ?️⛈
    Yes indead it rains now ;-)
    Wrote a script that asks for variable each hour and makes a debug or mail.
    but in my test i did not get any other Value than "0" out of the Rainradar !?
    Maybe i did something wrong?
  • Hi @pblacky I have tried your script and I do get a value from the Buienradar Rain QuickApp.
    But rain must be expected, I my case within 96 minutes.
    I thought if it was raining right now, the value should be greater than "0".
    Is that wrong?
    I have set the geodata both in my HC3 and in the variables. Which dates are preferred here?
    Is that wrong?
    if no rain is expected the next two hours, the value is 0
    if rain is expected, the value is the amount of minutes before rain
    if it is raining, the value is 999
    for testing purpose, you can force the QuickApp to expected rain or raining:
    Or
    If you remove the - -  and save the QuickApp, you can simulate on of the two situation.
    The QuickApp uses the lattitude and longitude settings in the two QuickApp variables. If you don’t set them yourself, the QuickApp will get them from your HC3 location. You can always overwrite them with the values you want.
    Test with the variable worked, so I can confirm that your QuickApp is running correctly ;-)
    it's a shame that it's raining heavily here in Vienna and the QuickApp shows "no rain".
    So obviously the weather service here in Vienna has no correct informative value ;-(
    If I look at:
    The graphic doesn’t cover Vienna ???
    i think there is some room for improvement, QA says "rain expected in 50min", however the expected amount of rain is 0,1mm/h (077), that not ever real drizzle, so bit misleading "rain expected" statement.
  • Technicaly more than “000” is rain in Buienradar terms. I could add the amount of rain, like when it is raining, to make it more specific to know if you have to put bags with sand in front of your door or it is just a sneeze. ?
    The problem with rain is, most of the time it starts with a drizzle. But 5 minutes later, the Buienradar interval, all hell breaks loose (or not).
    i know, but that 077 seems to be (in my case) just a noise, watching the raw data since 2hrs or so, the 077 was multiple times for multiple periods of time, however no rain since hours, no clouds on the sky (i can see every single rock on mars), no clouds on Buienradar map for my city.
    Buienradar Rain uses the same data as the Buienradar App (in two hour mode), so they should give the same prediction.
    It is a prediction, not a garantee. Buienradar Rain has an algoritme wether the clouds will drop there content. Sometimes it is an easy prediction, otherwise it is difficult. For example pop-up clouds are difficult for rain prediction. Also Buienradar Rain is only a prediction. It doesn’t have actual rain. If you want a precise actual rain, you need a rain sensor, with a risk you are too late.
    That is why in the QuickApp there are two intervals to check the Buienradar Rain data. If rain is expected, the QuickApp goes to an 1 minute interval, a sort of countdown, to get the next 5 minute prediction as soon as possible. If rain is expected within 5 minutes, the QuickApp assumes it is raining. Otherwise it will always report that rain is expected.
    10 hours ago, SmartHomeEddy said:
    If I look at:
    I am very confused right now!
    I see all of Austria on the map you posted, Vienna is where I made the red mark. So I thought it supported all areas that are visible on the map?
    That would also be Vienna!
    Maybe there is someone in my area who also uses your great tool, then we can clarify that ;-)
    I find it very useful for me!
    Edited by pblacky
  • Yes, the red cirkel is on the map, but look at my video you see the measurements stop just before Vienna. ?
    maybe a blunt question, but are the latitude and longitude settings in the QuickApp Variables the right ones?
    (Just asking)
    I installed the QA over 1 week ago and it has been raining heavily here for a few days.
    My location is south of Stuttgart and the geodata are entered correctly. That means at the
    first start the QA read out incorrect values from the HC3, which I then had to correct manually in the variables.
    So, despite the rain, nothing happens here. (
    [25.08.2020] [11:56:43] [DEBUG] [BUIENRADAR_RAIN_94]: OnInit)
    To me it looks like the QA only provides correct values for Netherlands but is useless for the rest.
    Maybe someone knows a weather service that can be used instead of buienrader.
  • Thanks @jwi I change the description to Netherlands (and Belgium, a part of Germany and a small part of France and England), apperently only there useful.
    I have put out a question at Buienradar for the coverage and I wil make a test QuickApp to query all latitude and longitude combination.
    Everyone can try with this link, if there is any data:
    Fill in the right latitude and longitude.
    It should return something like this if it rains, or with all 000 if it doesn’t rains:
