SmartHomeEddy
This QuickApp can be used as your Fibaro Homecenter 3 Weather Provider (Settings - 6. General - Main - Main Devices - Weather Provider)
The Buienradar Weather QuickApp contains the current Dutch weather measurements, the weather forecast and the 5-day forecast
The 5-days forecast is shown in the labels and the tomorrow forecast is shown in the child devices
The current observations are measured by KNMI weather stations spread across The Netherlands and are updated every 10 minutes
The weather report is updated several times a day by the Buienradar meteorologists
The QuickApp has child devices for:
  • Temperature °C
  • Feel temperature °C
  • Ground temperature °C
  • Humidity %
  • Absolute humidity g/m³
  • Airpressure hPa
  • Windspeed m/s
  • Windspeed km/h
  • Winddirectiondegrees ° (plus wind direction and arrow)
  • Windspeed Bft
  • Windgusts km/h
  • Rain mm/h
  • Rain Last 24h mm
  • Sunpower Watt/m²
  • Visibility km
  • Sunset (time)
  • Sunrise (time)
  • Sun Chance tomorrow %
  • Min Temp tomorrow °C
  • Max Temp tomorrow °C
  • Rain Chance tomorrow %
  • Min Rain tomorrow mm/h
  • Max Rain tomorrow mm/h
  • Wind tomorrow m/s (plus wind direction and arrow)
  • Wind tomorrow km/h (plus wind direction and arrow)
This QuickApp is plug-and-play. The only thing you can do, is change the Station ID to a weather-station nearby from the list or add some nice icons to the devices.
  • Wind Chill (based on the JAG/TI-method) and is only valid for temperatures between -46 C and +10 C and is only valid for wind speed between 1.3 m/s and 49 m/s
  • Windspeed is shown in m/s (km/3.6)
  • Absolute humidity is the measure of water vapor (moisture) in the air, regardless of temperature. It is expressed as grams of moisture per cubic meter of air (g/m3)
  • conditionCodes = {unavailable = 3200, clear = 32, rain = 40, snow = 43, storm = 38, cloudy = 30, fog = 20,}
  • The time shown in the QuickApp, is the last time of the measurement from Buienradar (not the system time)
Changes version 3.0 (23rd March 2022)
  • Added 5-days forecast to the labels
  • Addded child devices for:
    •   Windspeed km/h
    •   Windspeed Bft
    •   Windgusts km/h
    •   Rain Last 24h mm
  • Changed SunPower device type to powerSensor
  • Changed all Wind devices types to windSensor
  • Converted date-times to more nice format
  • Quickapp variable setGlobalVar changed to boolean
  • Added Quickapp variable stationWarning to show a warning (once) if your station hasn't got some weather value (default is true)
  • Optimised some code
Changes version 2.1 (15th January 2021)
  • Added weatherdescription:
    • "Mix van opklaringen en hoge bewolking" to conditioncode "cloudy"
    • "Half bewolkt" to conditioncode "cloudy"
    • "Opklaring en lokaal nevel of mist" to conditioncode "fog"
    • "Zwaar bewolkt met lichte sneeuwval" to conditionCode "snow"
    • "Zwaar bewolkt met regen en winterse neerslag" to conditioncode "snow"
    • "Afwisselend bewolkt met lichte sneeuwval" to conditioncode "snow"
    • "Zware sneeuwval" to conditioncode "snow"
    • "Opklaringen en kans op enkele pittige (onweers)buien" to conditioncode "rain"
    • "Bewolkt en kans op enkele pittige (onweers)buien" to conditioncode "rain"
  • Added Airpressure Text in log of Airpressure Child Device
Changes version 2.0 (3rd January 2021)
  • Added Child Devices for:
    • Temperature °C (including feeltemperature and groundtemperature)
    • Humidity %
    • Airpressure hPa
    • Windspeed m/s (including windspeedBft and Windgust km/h)
    • Winddirectiondegrees ° (including winddirection and arrow)
    • Rain mm/h (including rainFallLast24Hour mm)
    • Sunpower watt/m²
    • Visibility km
    • Sunset (time)
    • Sunrise (time)
  • Re-arranged the labels
  • Added backup station functionality for weather stations that don't have all the data, the data from 6260 Meetstation De Bilt is used.
  • Improved check for missing data
  • Added Quickapp variable for debug level (1=some, 2=few, 3=all). Recommended default value is 1.
Changes version 1.0 (25th October 2020)
  • Added weatherdescription "Zwaar bewolkt met wat lichte regen" to conditionCode "rain"
Changes version 0.6 (9th September 2020)
  • Changed conditionCodes storm = 38 snow = 43 and unknown = unavailable
  • Added weatherdescription "Afwisselend bewolkt met (mogelijk) wat lichte regen" to conditionCode "rain" and and "Afwisselend bewolkt met lokaal mist(banken)" to conditionCode "fog"
Changes version 0.5 (4th September 2020)
  • Added wind direction, air pressure and feel temperature to QuickApp labels
  • Changed stationname to regio in labels and log
  • Changed the names of the Global Variables to meet the Fibaro standards and shortened them (please manually delete your old ones and change the names in your scenes)
  • Added an extra check for response of Buienradar (jsonTable)
Changes version 0.4 (22nd August 2020)
  • Completely renewed code
  • Several Global Variables are available for personal use
  • Added QuickApp variable SetGlobalVar true or false, whether you want to use the Global Variables
  • Added QuickApp variable Timeout for finetuning waiting for response
Changes version 0.3 (11th August 2020)
  • error message instead of debug message in case of an error
  • Changed method of adding QuickApp variables, so they can be edited
Weather conditions:
The Buienradar weather description is converted to the right Fibaro condition codes, with the icons:
/monthly_2020_09/0F1673AC-6806-4F30-B7DA-26BCD55F5063.jpeg.029fe086520bc114b2008f60d968c359.jpeg" /> 8439B8B3-FF29-4622-9404-4069C546CFEA.jpeg.e7853a62d6ba1d92d5d2692a311bd076.jpeg 633D017C-C775-40E9-9C4E-55464662FEAF.jpeg.7a96145ee6996ba741caaa027f112b6b.jpeg 04B8D106-83B2-4910-9D6A-E09DA3311C9A.jpeg.102f44a17adf1ffaa38509218daf3eb6.jpeg A1DF2579-442F-484B-B44E-C505C87CB8FB.jpeg.94df0499dddbed12ebfb16d832d882bd.jpeg 3D5316E8-987A-4C02-AE3C-98528F0549C0.jpeg.c00a4ace403c4bd8d84729240b59d2e3.jpeg 8E3B81BA-123B-483E-82A4-DE7FC6D8A6F5.jpeg.05be6ce402c8e889022a0b2773f12e42.jpeg
Fibaro Dashboard:
The Fibaro properties Temperature, Humidity and Wind values are updated to show in your dashboard:
Mobile App:
For the Mobile app these values are available:
For the most accurate measurements you can select a Station in your neighborhood:
6391 Meetstation Arcen / 6275 Meetstation Arnhem / 6249 Meetstation Berkhout / 6308 Meetstation Cadzand / 6260 Meetstation De Bilt / 6235 Meetstation Den Helder / 6370 Meetstation Eindhoven / 6377 Meetstation Ell / 6321 Meetstation Euro platform / 6350 Meetstation Gilze Rijen / 6323 Meetstation Goes / 6283 Meetstation Groenlo-Hupsel / 6280 Meetstation Groningen / 6315 Meetstation Hansweert / 6278 Meetstation Heino / 6356 Meetstation Herwijnen / 6330 Meetstation Hoek van Holland / 6279 Meetstation Hoogeveen / 6251 Meetstation Hoorn Terschelling / 6258 Meetstation Houtribdijk / 6285 Meetstation Huibertgat / 6209 Meetstation IJmond / 6225 Meetstation IJmuiden / 6277 Meetstation Lauwersoog / 6320 Meetstation LE Goeree / 6270 Meetstation Leeuwarden / 6269 Meetstation Lelystad / 6348 Meetstation Lopik-Cabauw / 6380 Meetstation Maastricht / 6273 Meetstation Marknesse / 6286 Meetstation Nieuw Beerta / 6312 Meetstation Oosterschelde / 6344 Meetstation Rotterdam / 6343 Meetstation Rotterdam Geulhaven / 6316 Meetstation Schaar / 6240 Meetstation Schiphol / 6324 Meetstation Stavenisse / 6267 Meetstation Stavoren / 6229 Meetstation Texelhors / 6331 Meetstation Tholen / 6290 Meetstation Twente / 6313 Meetstation Vlakte aan de Raan / 6242 Meetstation Vlieland / 6310 Meetstation Vlissingen / 6375 Meetstation Volkel / 6215 Meetstation Voorschoten / 6319 Meetstation Westdorpe / 6248 Meetstation Wijdenes / 6257 Meetstation Wijk aan Zee / 6340 Meetstation Woensdrecht / 6239 Meetstation Zeeplatform F-3 / 6252 Meetstation Zeeplatform K13
QuickApp variables (mandatory, they will be automatically added with the default values):
  • interval = Number in seconds to update the data (defaul = 601)
  • timeout = Number in seconds to wait for a response (default = 5)
  • stationID = Number of the station you want to use for weather measurements (default = 6260 Meetstation De Bilt)
  • backupstationID = Number of the backup station for missing weather data from stations that don't have all the data (default = 6260 Meetstation De Bilt). Don't change this ID unless you know what you are doing.
  • setGlobalVar = true or false, whether you want tu use the Global Variables (default = false)
  • stationWarning = true or false, whether you want to receive warnings if your station hasn't got some weather value (default is true)
  • debugLevel = Number (1=some, 2=few, 3=all) (default = 1)
or Fibaro Marketplace:
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
JSON data copyright: (C)opyright Buienradar / RTL. All rights reserved JSON data terms: This feed may be used freely under condition of source reference buienradar.nl including a hyperlink to https://www.buienradar.nl. The feed cannot be derived from users or other persons.
Edited by SmartHomeEddy
  • Extra function:
    This QuickApp can store all general and station specific weather information in global variables. These global variables you can use in your own scripts, for example to send an email every morning with the weather forecast, send notifications of weather changes, etcetera. To use the Global Variables, you need to set the QuickApp variable “setGlobalVar” to “true”.
    Global Variables (if QuickApp variable setGlobalVar = true):
    • brShortterm_[deviceID]
    • brLongterm_[deviceID]
    • brFivedayforecast_1_[deviceID]
    • brFivedayforecast_2_[deviceID]
    • brFivedayforecast_3_[deviceID]
    • brFivedayforecast_4_[deviceID]
    • brFivedayforecast_5_[deviceID]
    • brWeatherreport_[deviceID]
    • brStation_[deviceID]
    Examples of the Global Variables:
    {"startdate":"2020-08-23T00:00:00","enddate":"2020-08-27T00:00:00","forecast":"Onbestendig met geregeld regen of enkele buien.","$id":"58"}
    /monthly_2020_08/4F4912E8-0E4F-4A11-9622-E0C49D4E7D6D.jpeg.b2196cd8e0bda573b0bb5f54ba50dde0.jpeg" />
    {"startdate":"2020-08-28T00:00:00","enddate":"2020-09-01T00:00:00","forecast":"Aanvankelijk onbestendig met maxima iets onder het langjarig gemiddelde. Later in de periode neemt de kans op een droger en warmer weertype toe.","$id":"59"}
    brFivedayforecast_1_[deviceID] {"iconurl":"https://www.buienradar.nl/resources/images/icons/weather/30x30/f.png","mintemperatureMin":15,"maxtemperatureMax":21,"weatherdescription":"Afwisselendbewolkt met (mogelijk) wat lichte regen","mintemperature":"15","mintemperatureMax":15,"mmRainMax":5.0,"maxtemperature":"21","maxtemperatureMin":21,"wind":4,"windDirection":"w","mmRainMin":1.0,"sunChance":40,"day":"2020-08-23T00:00:00","rainChance":50,"$id":"60"}
    brFivedayforecast_2_[deviceID] {"iconurl":"https://www.buienradar.nl/resources/images/icons/weather/30x30/f.png","mintemperatureMin":14,"maxtemperatureMax":20,"weatherdescription":"Afwisselendbewolkt met (mogelijk) wat lichte regen","mintemperature":"14/15","mintemperatureMax":15,"mmRainMax":5.0,"maxtemperature":"19/20","maxtemperatureMin":19,"wind":3,"windDirection":"w","mmRainMin":2.0,"sunChance":30,"day":"2020-08-24T00:00:00","rainChance":70,"$id":"61"}
    brFivedayforecast_3_[deviceID] {"iconurl":"https://www.buienradar.nl/resources/images/icons/weather/30x30/f.png","mintemperatureMin":13,"maxtemperatureMax":22,"weatherdescription":"Afwisselendbewolkt met (mogelijk) wat lichte regen","mintemperature":"13/15","mintemperatureMax":15,"mmRainMax":6.0,"maxtemperature":"20/22","maxtemperatureMin":20,"wind":4,"windDirection":"zw","mmRainMin":2.0,"sunChance":30,"day":"2020-08-25T00:00:00","rainChance":80,"$id":"62"}
    brFivedayforecast_4_[deviceID] {"iconurl":"https://www.buienradar.nl/resources/images/icons/weather/30x30/f.png","mintemperatureMin":16,"maxtemperatureMax":21,"weatherdescription":"Afwisselendbewolkt met (mogelijk) wat lichte regen","mintemperature":"16/17","mintemperatureMax":17,"mmRainMax":3.0,"maxtemperature":"19/21","maxtemperatureMin":19,"wind":5,"windDirection":"w","mmRainMin":1.0,"sunChance":30,"day":"2020-08-26T00:00:00","rainChance":60,"$id":"63"}
    {"iconurl":"https://www.buienradar.nl/resources/images/icons/weather/30x30/f.png","mintemperatureMin":13,"maxtemperatureMax":20,"weatherdescription":"Afwisselendbewolkt met (mogelijk) wat lichte regen","mintemperature":"13/15","mintemperatureMax":15,"mmRainMax":3.0,"maxtemperature":"19/20","maxtemperatureMin":19,"wind":3,"windDirection":"zw","mmRainMin":1.0,"sunChance":40,"day":"2020-08-27T00:00:00","rainChance":70,"$id":"64"}
    {"published":"2020-08-22T10:00:00","authorbio":"Sinds 2017 als junior Meteoroloog actief voor het weekendteam van Buienradar. Daarnaast student van de Bachelor Bodem, Water & Atmosfeer aan de Wageningen Universiteit.","author":"Philippe Schambergen","text":"Na de warmte van de afgelopen weken gaat het roer nu flink om. De komende tijd is het wisselvallig in Nederland met normale temperaturen en vooral op woensdag staat er veel wind.Vandaag is het wisselend bewolkt en is het in het binnenland nog geruime tijd droog. In de loop van de dag gaan er vanuit het noordwesten buien vallen met in het noorden kans op onweer. Na het middaguur trekken deze buien verder landinwaarts. Tussen de buien door blijft er echter genoeg ruimte voor de zon. Het wordt 21 of 22 graden langs de kust en nog een zomerse 25 graden in het zuidoosten. Er staat een matige en aan zee krachtige zuidwestenwind, windkracht 4 tot 6. Ook komen er in heel het land windstoten rond de 50 km/h voor, tijdens buien mogelijk oplopend tot 75 km/h. Aan het eind van de middag komt er langs de zuidwestkust mogelijk een harde zuidwestenwind te staan, windkracht 7.Vanavond klaart het op en trekken de meeste buien naar het oosten weg. Het blijft nog even stevig waaien. Vannacht neemt de wind in het binnenland iets af en verdwijnen daar de windstoten. Er gaan wel opnieuw buien ontstaan in het noorden van het land. Het koelt af naar 17 graden aan zee en 14 graden in het binnenland. Morgen is het wisselend bewolkt en trekken enkele buien over het land. Er staat wel iets minder wind dan vandaag: de westenwind waait matig tot aan zee (vrij) krachtig. In de middag wordt het nog maar 20 graden op de Wadden en 22 graden in het zuidoosten van het land, waarmee de temperatuur rond normaal komt te liggen.De dagen erna is het wisselvallig met enkele buien waarbij het vooral in het noorden soms flink kan doorregenen. Een depressie ligt woensdag boven de Noordzee en deze zorgt dan voor een flinke toename van de wind. Mogelijk wordt het zelfs even stormachtig! In de middag wordt het 19 tot 22 graden, alleen dinsdag kan het in het zuidoosten wel weer 24 graden worden.","title":"Terug naar normaal","summary":"Na de warmte van de afgelopen weken gaat het roer nu flink om. De komende tijd is het wisselvallig in Nederland met normale temperaturen en vooral op woensdag staat er veel wind.","$id":"57"}
    {"regio":"Rotterdam","timestamp":"2020-08-22T11:40:00","airpressure":1013.1,"lat":51.95,"weatherdescription":"Zwaar bewolkt","rainFallLast24Hour":0.6,"feeltemperature":20.3,"precipitation":0.0,"stationname":"Meetstation Rotterdam","lon":4.45,"$id":"36","temperature":20.3,"graphUrl":"https://www.buienradar.nl/nederland/weerbericht/weergrafieken/c","windgusts":14.4,"sunpower":349.0,"rainFallLastHour":0.0,"winddirection":"ZW","stationid":6344,"groundtemperature":20.7,"winddirectiondegrees":215,"humidity":68.0,"windspeedBft":5,"windspeed":9.3,"visibility":25300.0,"iconurl":"https://www.buienradar.nl/resources/images/icons/weather/30x30/c.png"}
    I could use someone to give it a try with the Global Variables, with some Lua scripting for additional functionality. Are the Global Variables of good use? Do they serve a purpose?
    If they are, maybe post we could some examples here for other users to use.
    looks very nice!!
    In HC2 i use OWM.
    I would like to know if and how I can get :clear sky, cloudy, scattered clouds  etcetra.
    This I use in HC2 to close curtain in the morning so I dont look into the sun.
    In the afternoon to prevent seeing window in reflection on tele.
    By storm the roller shiutters should go down.
    Thanks in advance,
    //Sjakie
  • @Sjakie Do you mean the “conditions” —>  "unknown", "clear", "rain", "snow", "storm", "cloudy", "fog" ?
    (that is where the icon of the weather provider is triggered on)
  • How to get a value from one of the Global Variables?
    This is the content of the Global Variable brStation_[quickappID] (where the measurement of your station is stored):
    This is how the structure looks like (I used
    This is an example to get one of the values (in this case 'weatherdescription') from the Global Variable brStation_[quickappID].
    ([quickappID] is the device number of your setup)
    This is the result in the debugger:
    Changed to shorter Global Variable name
    Hi SmartHomeEddy,
    I really like this QuickApp – ‘Buienradar Weather ??’.
    Installing the QuickApp was very easy, and it does exactly what I wanted it to do.
    Being able to use the Dutch ‘Buien Radar’ as my HC3 weather provider.
    I also like the option of the global variables.
    They do exactly what you can expect from them.
    It’s a very nice option.
    I would say, keep on baking these kind of codes...
    and thank you very much for sharing, SmartHomeEddy
    Edited by NLWaard
    Also looks good in the new 'Fibaro Home Center' App version 1.9..
    I like it.
  • I have uploaded a new version of the Buienradar Weather QuickApp.
    The main changes are:
    • Added wind direction, air pressure and feel tempersture to QuickApp labels
    Because the new Mobile app now supports QuickApps more, it makes sense to show more information in the QuickApp and thus also in the Mobile App.
    ‼️ If you use the Buienradar Global Variables, the names are changed to a shorter format. Please delete the old Global Variables, the QuickApp will make the new ones. And change the shorter names in your scenes.
    weather conditions seems to be (afaik) wrong in the example QA on HC3 (snow = 38, storm = 666). Storm is 38 and snow 43 (set snow, refresh BUI and watch the icon ...)
    Additionally the BUI seems to use "unavailable" and not "unknown" for code 3200, this has been documented properly in
    but not (yet) changed in QA Weather example, i posted that some time ago:
  • Thanks @tinman !
    I apparently missed that post, I used the example for the codes. I will change them; snow, storm, unavailable.
    (I don’t know for sure if I have got all the possible “weatherdescription” from Buienradar, so maybe, if the weather changes more to winter, I get some more weatherdescriptions to convert to the conditionCodes.)
    EDIT: I found two new weatherdescriptions “Afwisselend bewolkt met (mogelijk) wat lichte regen” and "Afwisselend bewolkt met lokaal mist(banken)". Added for the new version
    Hi All,
    in version 0.3 it was possible to get reading directly as fibaro weather provider. now in the last version only weather status and the rest appears to be 0.
    I already dit a clean install of the quickapp but didn't help so far. So did somebody remove some stuff inside the code ?
    Thanks / bedankt :)
  • Hi @Hearts
    It suposed to show the three values and weather icon like this
    /monthly_2020_08/4B59AF15-1180-480A-B9B6-316105AB8DDF.jpeg.f04529f6af83d4fd947a75292059edf9.jpeg" />
    If you look at the QuickApp screen, in preview of on your mobile, what do you see?
    HI @
    thanks for your reply!
    in the QuickApp on mobile I see al the details. Like station, temp etc.  In browser I see also details. But the weather station appears to be empty.
    In general settings Weather provider: is set to Achter Tuin | Buienradar weather
    Thanks in advance
  • @Hearts
    I suspect the QuickApp doesn’t runs completely.
    You don’t have messages in the log?
    Which weather station do you use?
    What you could do is on line 251 remove the - - in front of this code:
    If you save the changes, the Quickapp restarts and in the log you should see the “OnInit” and the "------ END ------" debug message. Then the loop is compleet, otherwise not (and the QuickApp crashed).
  • Sorry, my bad. That is in the upcomming version. But it is around 251. It is in this part:
    BTW if you look at your HC3 dashboard with the weather provider in te top lines, that screen isn’t alway updated. You will see the time is offset. So a refresh in the screen maybe helps.
    So remove the two — save the changes and look at your log. Do you see “onInit” and the "------ END ------" debug messages?
    Ah ok thanks!
    I removed -- and in the log i was getting the following information, nothing else:
    I refreshed already many times and the time is 14:14 should be ok.
    Did you still have version 0.3 ?
    I like to post some screenshots i get the same error like anybody else on the forum so maybe next post....
    Edited by Hearts
  • Version 0.6 is available with two interesting changes:
    I have seen them all, thanks!
  • A new version of the Buienradar Weather QuickApp is available.
    The QuickApp now can also handle weatherdescription "Zwaar bewolkt met wat lichte regen" to conditionCode "rain"
