SmartHomeEddy
This QuickApp can be used as your Fibaro Homecenter 3 Weather Provider (Settings - 6. General - Main - Main Devices - Weather Provider)
The Buienradar Weather QuickApp contains the current Dutch weather measurements, the weather forecast and the 5-day forecast
The 5-days forecast is shown in the labels and the tomorrow forecast is shown in the child devices
The current observations are measured by KNMI weather stations spread across The Netherlands and are updated every 10 minutes
The weather report is updated several times a day by the Buienradar meteorologists
The QuickApp has child devices for:
  • Temperature °C
  • Feel temperature °C
  • Ground temperature °C
  • Humidity %
  • Absolute humidity g/m³
  • Airpressure hPa
  • Windspeed m/s
  • Windspeed km/h
  • Winddirectiondegrees ° (plus wind direction and arrow)
  • Windspeed Bft
  • Windgusts km/h
  • Rain mm/h
  • Rain Last 24h mm
  • Sunpower Watt/m²
  • Visibility km
  • Sunset (time)
  • Sunrise (time)
  • Sun Chance tomorrow %
  • Min Temp tomorrow °C
  • Max Temp tomorrow °C
  • Rain Chance tomorrow %
  • Min Rain tomorrow mm/h
  • Max Rain tomorrow mm/h
  • Wind tomorrow m/s (plus wind direction and arrow)
  • Wind tomorrow km/h (plus wind direction and arrow)
This QuickApp is plug-and-play. The only thing you can do, is change the Station ID to a weather-station nearby from the list or add some nice icons to the devices.
  • Wind Chill (based on the JAG/TI-method) and is only valid for temperatures between -46 C and +10 C and is only valid for wind speed between 1.3 m/s and 49 m/s
  • Windspeed is shown in m/s (km/3.6)
  • Absolute humidity is the measure of water vapor (moisture) in the air, regardless of temperature. It is expressed as grams of moisture per cubic meter of air (g/m3)
  • conditionCodes = {unavailable = 3200, clear = 32, rain = 40, snow = 43, storm = 38, cloudy = 30, fog = 20,}
  • The time shown in the QuickApp, is the last time of the measurement from Buienradar (not the system time)
Changes version 3.0 (23rd March 2022)
  • Added 5-days forecast to the labels
  • Addded child devices for:
    •   Windspeed km/h
    •   Windspeed Bft
    •   Windgusts km/h
    •   Rain Last 24h mm
  • Changed SunPower device type to powerSensor
  • Changed all Wind devices types to windSensor
  • Converted date-times to more nice format
  • Quickapp variable setGlobalVar changed to boolean
  • Added Quickapp variable stationWarning to show a warning (once) if your station hasn't got some weather value (default is true)
  • Optimised some code
Changes version 2.1 (15th January 2021)
  • Added weatherdescription:
    • "Mix van opklaringen en hoge bewolking" to conditioncode "cloudy"
    • "Half bewolkt" to conditioncode "cloudy"
    • "Opklaring en lokaal nevel of mist" to conditioncode "fog"
    • "Zwaar bewolkt met lichte sneeuwval" to conditionCode "snow"
    • "Zwaar bewolkt met regen en winterse neerslag" to conditioncode "snow"
    • "Afwisselend bewolkt met lichte sneeuwval" to conditioncode "snow"
    • "Zware sneeuwval" to conditioncode "snow"
    • "Opklaringen en kans op enkele pittige (onweers)buien" to conditioncode "rain"
    • "Bewolkt en kans op enkele pittige (onweers)buien" to conditioncode "rain"
  • Added Airpressure Text in log of Airpressure Child Device
Changes version 2.0 (3rd January 2021)
  • Added Child Devices for:
    • Temperature °C (including feeltemperature and groundtemperature)
    • Humidity %
    • Airpressure hPa
    • Windspeed m/s (including windspeedBft and Windgust km/h)
    • Winddirectiondegrees ° (including winddirection and arrow)
    • Rain mm/h (including rainFallLast24Hour mm)
    • Sunpower watt/m²
    • Visibility km
    • Sunset (time)
    • Sunrise (time)
  • Re-arranged the labels
  • Added backup station functionality for weather stations that don't have all the data, the data from 6260 Meetstation De Bilt is used.
  • Improved check for missing data
  • Added Quickapp variable for debug level (1=some, 2=few, 3=all). Recommended default value is 1.
Changes version 1.0 (25th October 2020)
  • Added weatherdescription "Zwaar bewolkt met wat lichte regen" to conditionCode "rain"
Changes version 0.6 (9th September 2020)
  • Changed conditionCodes storm = 38 snow = 43 and unknown = unavailable
  • Added weatherdescription "Afwisselend bewolkt met (mogelijk) wat lichte regen" to conditionCode "rain" and and "Afwisselend bewolkt met lokaal mist(banken)" to conditionCode "fog"
Changes version 0.5 (4th September 2020)
  • Added wind direction, air pressure and feel temperature to QuickApp labels
  • Changed stationname to regio in labels and log
  • Changed the names of the Global Variables to meet the Fibaro standards and shortened them (please manually delete your old ones and change the names in your scenes)
  • Added an extra check for response of Buienradar (jsonTable)
Changes version 0.4 (22nd August 2020)
  • Completely renewed code
  • Several Global Variables are available for personal use
  • Added QuickApp variable SetGlobalVar true or false, whether you want to use the Global Variables
  • Added QuickApp variable Timeout for finetuning waiting for response
Changes version 0.3 (11th August 2020)
  • error message instead of debug message in case of an error
  • Changed method of adding QuickApp variables, so they can be edited
Weather conditions:
The Buienradar weather description is converted to the right Fibaro condition codes, with the icons:
/monthly_2020_09/0F1673AC-6806-4F30-B7DA-26BCD55F5063.jpeg.029fe086520bc114b2008f60d968c359.jpeg" /> 8439B8B3-FF29-4622-9404-4069C546CFEA.jpeg.e7853a62d6ba1d92d5d2692a311bd076.jpeg 633D017C-C775-40E9-9C4E-55464662FEAF.jpeg.7a96145ee6996ba741caaa027f112b6b.jpeg 04B8D106-83B2-4910-9D6A-E09DA3311C9A.jpeg.102f44a17adf1ffaa38509218daf3eb6.jpeg A1DF2579-442F-484B-B44E-C505C87CB8FB.jpeg.94df0499dddbed12ebfb16d832d882bd.jpeg 3D5316E8-987A-4C02-AE3C-98528F0549C0.jpeg.c00a4ace403c4bd8d84729240b59d2e3.jpeg 8E3B81BA-123B-483E-82A4-DE7FC6D8A6F5.jpeg.05be6ce402c8e889022a0b2773f12e42.jpeg
Fibaro Dashboard:
The Fibaro properties Temperature, Humidity and Wind values are updated to show in your dashboard:
Mobile App:
For the Mobile app these values are available:
For the most accurate measurements you can select a Station in your neighborhood:
6391 Meetstation Arcen / 6275 Meetstation Arnhem / 6249 Meetstation Berkhout / 6308 Meetstation Cadzand / 6260 Meetstation De Bilt / 6235 Meetstation Den Helder / 6370 Meetstation Eindhoven / 6377 Meetstation Ell / 6321 Meetstation Euro platform / 6350 Meetstation Gilze Rijen / 6323 Meetstation Goes / 6283 Meetstation Groenlo-Hupsel / 6280 Meetstation Groningen / 6315 Meetstation Hansweert / 6278 Meetstation Heino / 6356 Meetstation Herwijnen / 6330 Meetstation Hoek van Holland / 6279 Meetstation Hoogeveen / 6251 Meetstation Hoorn Terschelling / 6258 Meetstation Houtribdijk / 6285 Meetstation Huibertgat / 6209 Meetstation IJmond / 6225 Meetstation IJmuiden / 6277 Meetstation Lauwersoog / 6320 Meetstation LE Goeree / 6270 Meetstation Leeuwarden / 6269 Meetstation Lelystad / 6348 Meetstation Lopik-Cabauw / 6380 Meetstation Maastricht / 6273 Meetstation Marknesse / 6286 Meetstation Nieuw Beerta / 6312 Meetstation Oosterschelde / 6344 Meetstation Rotterdam / 6343 Meetstation Rotterdam Geulhaven / 6316 Meetstation Schaar / 6240 Meetstation Schiphol / 6324 Meetstation Stavenisse / 6267 Meetstation Stavoren / 6229 Meetstation Texelhors / 6331 Meetstation Tholen / 6290 Meetstation Twente / 6313 Meetstation Vlakte aan de Raan / 6242 Meetstation Vlieland / 6310 Meetstation Vlissingen / 6375 Meetstation Volkel / 6215 Meetstation Voorschoten / 6319 Meetstation Westdorpe / 6248 Meetstation Wijdenes / 6257 Meetstation Wijk aan Zee / 6340 Meetstation Woensdrecht / 6239 Meetstation Zeeplatform F-3 / 6252 Meetstation Zeeplatform K13
QuickApp variables (mandatory, they will be automatically added with the default values):
  • interval = Number in seconds to update the data (defaul = 601)
  • timeout = Number in seconds to wait for a response (default = 5)
  • stationID = Number of the station you want to use for weather measurements (default = 6260 Meetstation De Bilt)
  • backupstationID = Number of the backup station for missing weather data from stations that don't have all the data (default = 6260 Meetstation De Bilt). Don't change this ID unless you know what you are doing.
  • setGlobalVar = true or false, whether you want tu use the Global Variables (default = false)
  • stationWarning = true or false, whether you want to receive warnings if your station hasn't got some weather value (default is true)
  • debugLevel = Number (1=some, 2=few, 3=all) (default = 1)
or Fibaro Marketplace:
How to install:
  1. Open the Configuration Interface
  2. Go to Settings > Devices
  3. Click  +
  4. Choose Other Device
  5. Choose Upload File
  6. Choose file from your computer with .fqa
JSON data copyright: (C)opyright Buienradar / RTL. All rights reserved JSON data terms: This feed may be used freely under condition of source reference buienradar.nl including a hyperlink to https://www.buienradar.nl. The feed cannot be derived from users or other persons.
Edited by SmartHomeEddy
  • Sneak Preview of the next version 2.0
    • Like 5
    Great, I use the 1.0 version and works perfect on the HC3.
    Tip: is it possible to make the debug under a variable, false or true. When the QA works perfect is al lot of message in debug list no needed.
  • Hi @twanve, thanks, in the next version debug and trace message are off, only warnings and errors are on. Will look further in to it.
    Added debuglevel to the new version
  • The new version of Buienradar Weather is available (in the first post).
    Changes are:
      • Humidity %
      • Airpressure hPa
      • Sunpower watt/m²
      • Visibility km
      • Sunset (time)
      • Sunrise (time)
    New version downloaded and first remove old version 1.0.
    New .fqa install and "woh", I get now 12 new icons with data. My new HC3 more filled:-)
    Set weather station to my location and everything seems to work.
    Thx for you great job
    ps; when you have more time, I have one more
     to migrate:-)
  • A new version is available with the following changes:
    Weatherdescription and conditionCode
    I think i'm the only one. But i get an error:
    [19.01.2021] [20:06:00] [ERROR] [QUICKAPP255]: main.lua:646: attempt to call a nil value (field '?')
    Any ideas?
  • @ArjanP I will have a look
    Send you a pm for help
    Just remove the quickapp, reboot your HC3 and install de quickapp again. It works on my HC3 and with other users, so I think some strange thing happened.
    And heared from Arjan it worked.
    Using this QuickApp on HC3 and it works great! Easy to setup and gives plenty of oppertunities for automation! Like automatic scene start when sunny or reaching a certain temperature! Great work and thanks for sharing!
    Excellent! Prachtig :)
    This fits my needs. Thanks a lot.  Setting up the conditions for my shades inside the house, and the somfy IO driven blinds on the terrace. Great :)
    @SmartHomeEddy
    Been checkin your QA, and it works great. The only thing i am not sure about if
    the app can do  is, the rain expectation for the coming 3 hours.
    I would like to make a scene that notifies me about the coming rain. And then
    some follow up action that closes my sun shades outside.
    edit 2
    I see, you made another app for that....how cool :) Let me try that also
    Edited by ppeterr
    @SmartHomeEddy
    edit 2
    Indeed, for more accurate rain predictions, you need the QuickApp Buienradar Rain.
    Uhmmmm.....unknown..
    What i know, is that nothing changed. And it errors already for about 30mins...
    This needs some investigation.....but how :)
    [24.08.2021] [18:20:01] [ERROR] [QUICKAPP114]: QuickApp crashed[24.08.2021] [18:20:01] [ERROR] [QUICKAPP114]: Unknown error occurred:
    [edit] well, there was a hc3 update waiting 5.080.12. That cleared the error. Normally not the way i would go,  but well....unknown doesnt tell me anything.
    Edited by ppeterr
    maybe just the reboot did the job?
    That probably would have fixed it also, but we will never know :)
    Dear Eddy,
    QA buienrader weather crashes.
    Can you help me?
  • Hi @Fireman
    on my Buienradar Weather I saw at tonight at 23:51 no response from Buienradar. That can happen.
    But the quickapp should handle that correctly. Do you run version 2.1 ?
    (From version 2.0 error handling is better)
  • Which weather station do you use?
    And can you set debugLevel = 3 so we get some more debug messages?
  • Well, only setting debuglevel to 3 shouldn't be a solution, but sometimes restarting (that is a result of changing a quickapp variable) does give a quickapp a boost. Let's see if it stays ok.
