FamSetsaas 0
Dear experts,
I'm trying to do an HTTP call from LUA, to retrieve the external IP address. However, it is obvious that I need to wait for the response, but have not been able to find out exactly where to do this. Here is my code:
function myPublicIP(str)
fibaro:debug("A")
str = "https://api.ipify.org/?format=json"
local http = net.HTTPClient()
fibaro:debug("B")
http:request(str, {
success = function(status)
fibaro:debug("C")
fibaro:debug(status.status)
if status.status ~= 200 and status.status ~= 201 then fibaro:debug("failed"); end
fibaro:debug("D")
fibaro:debug(status.data);
result = json.decode(status.data)
ip = result.ip
fibaro:debug("E")
fibaro:debug(ip)
end,
error = function(err)
fibaro:debug('[ERROR] ' .. err)
fibaro:debug("F")
return ip
end -- function
fibaro:debug("G")
fibaro:debug(myPublicIP())
When running this, the debug output after "E" shows that the IP address is retrieved correctly. But this comes too late, and the function returns nil. So there is a need for a sleep (which I guess is the simplest) somewhere, but have not figured this out.
I do not really understand how the code is executed. The letters are output in this order: G A B F C D E. So I just need to ensure that C D E are completed before continuing to F.
Any help would be appreciated.
8 answers to this question
