PederAas 0
I'm new to this and now I'm quite confused. I have multiple fibaro dimmer 2's working in my house, all installed at the same time and using the same method. 4/4 have been working correctly, until one suddenly stopped working. It said it could not connect to the network, but showed under "my devices".
I force-removed it from my devices (Samsung Smartthings) and then tried to do a reset of the device, accordingly to what Fibaro recommends. But when trying to add it back into Smartthings, the dimmer does not respond as expected. When I press the dimmer three times rapidly, nothing happens. No LED-indicator, nothing. But if I press and hold, I enter the "menu" of the Dimmer. Therefore I'm quite confused; what am I doing wrong?
Best,
Peder
7 answers to this question
