QuickApp changing text size and color
josjg
I am looking for ways to change the fontsize and/or color of a QA panel. Seems to me that it should be done trough updateView, but I can only find the "text" and "value" properties documented (or rather, mentioned in this forum)
Is there a way to change the appearance of a QA?
Hi @josjg , I'm changing the text colors with html formating...
/monthly_2020_09/afbeelding.png.f3f3113f70aba31d7887d5eb2ce89bde.png" />
Enjoy coding :-D
P.S. This solution is not working in the app, only in BUI.
Edited by Bodyart
  • Thanks a lot @Bodyart I've used self:updateView with a label and passing inline CSS, and it works.
    Next thing I'm looking for is to change the color of a button in my QA. I've noticed the QA having a "viewXml" property set to true. Could that be the way in? Or should I look for [device].properties.viewLayout?
    Hello. I create a quick app  multisensor that displays a number  in dashboard of HC3 by using the updateProperty("value" ,number) .
    Is there a way to display a text instead of a number ? I used label but I have to click on quick app icon to see the label text but I want this text to be displayed on dashboard.
    Unit for the text behind the number and log for text under value / unit.
    Edited by SmartHomeEddy
    Great! Thank you @
     ! I can now appear the Unit of a number but Is there any way to display only the text. I want to create somthing like information box in dashboard. If this is not possible with this type of QA , is there an appropriate type to do this?  Thanks a lot!!
    P.S. This was very simple in VDs on HCL and HC2 by creating a Label and check the field "Main" and "Favorite"
    Edited by Prokopis Bor
    Only in the log field
    /monthly_2020_09/0CE20160-E450-41A0-A9C1-5DC687FCCD4A.jpeg.6ef5c5edf11c0712696328abfdb08b0e.jpeg" />
    • 4 months later...
    • 5 months later...
    In previous versions I could write two separate lines of log text, but in the new beta version the text ends up in a single long line.
    Is there any trick to force the text into two separate lines?
    Edited by RH_Dreambox
