QuickApp changing text size and color
I am looking for ways to change the fontsize and/or color of a QA panel. Seems to me that it should be done trough updateView, but I can only find the "text" and "value" properties documented (or rather, mentioned in this forum)
Is there a way to change the appearance of a QA?
Link to post
Hi @josjg , I'm changing the text colors with html formating...
-- color definitions
local crc,okc,erc,ekc,evc,xec,cnc,xcc="#03ff0e","#00ac08","#ff0303","#FFFACD","#FFA07A","#FF69B4","#1639ff","#B0E0E6","#7B68EE","#FFE4E1"
--function used to format
function span(col,str)return fmt("<b><font color="..col..">"..str.."</font></b>")end
-- General usage
self:updateView("lblTitle","text",span(crc,"Your text to be displayed"))
--Upper label with bigger font
self:updateView("lblTitle","text",string.format("<span class=\"section-title\"><b><font color=%s>📍 WeatherFlow station %s [%s]</font></b></span>",cnc,d.station_name,d.station_id))
Enjoy coding :-D
P.S. This solution is not working in the app, only in BUI.
Edited by Bodyart
Link to post
Thanks a lot @Bodyart I've used self:updateView with a label and passing inline CSS, and it works.
Next thing I'm looking for is to change the color of a button in my QA. I've noticed the QA having a "viewXml" property set to true. Could that be the way in? Or should I look for [device].properties.viewLayout?
Link to post
Hello. I create a quick app  multisensor that displays a number  in dashboard of HC3 by using the updateProperty("value" ,number) .
Is there a way to display a text instead of a number ? I used label but I have to click on quick app icon to see the label text but I want this text to be displayed on dashboard.
Link to post
Unit for the text behind the number and log for text under value / unit.
Edited by SmartHomeEddy
Link to post
Great! Thank you @SmartHomeEddy ! I can now appear the Unit of a number but Is there any way to display only the text. I want to create somthing like information box in dashboard. If this is not possible with this type of QA , is there an appropriate type to do this?  Thanks a lot!!
P.S. This was very simple in VDs on HCL and HC2 by creating a Label and check the field "Main" and "Favorite"
Edited by Prokopis Bor
Link to post
