dkeenaghan 0
I have a setup with two switches that control a light (actually two lights in series), there's no neutral at the switch and only two wires connecting the two switches. The attached diagram shows the situation.
Is it possible to install the Dimmer 2 (FDG-212) at either switch (if so how?) or do I need to look into replacing the switches with momentary switches?
/monthly_2020_09/image.png.53d1d64fa6e4af2d78c972188af828b1.png" />Please login or register to see this attachment.
Edited by dkeenaghanadded model number
3 answers to this question
