favourite device home center app with hc3
royred
hi,
i cant see  favorite device in home center app with my new hc3
there is no problem with hcl
thanks
7 answers to this question
@royred
1) the user must have the device authorization assigned in HC3 (they can be different for each user)
2) then select from the list of loads / scenes to favorites (asterisk)
Hi
I've just migrated from HC2 to HC3 and can't see any devices in my Favourites section of app, running on iOs.  Logged in as and admin user.
I can see the devices when going into each room, but not on the home/favourites area.
Any idea how to fix this?
Is there any update on this?
Did anyone fond the solution?
In my case I am using fresh HC3 installation added 6 sensors and a siren.
Logged in as admin (so all devices can be accessed).
The Dashboard shows siren but no sensors. The Home screen shows all sensors correctly though.
Is it actually possible sensors to be labeled as "Favorite"?
Thank you
