Can you change email notification from name?
UriT
Have a newly setup up HC3 have started migrating all the rules I had in my old Zipato Zipatiles.
At this stage I am sticking to Block Scenes until I skill up in LUA (although did manage to copy and paste a few scripts into QA for http calls)
I have managed to get email notifications working but wondering if you can change the "From" address anywhere ... at the moment it comes through as
HC3-0000xxxxx
Message from FIBARO
<My message in here>
At a min ideally I would like to replace the HC-0000xxxx with something like "Message from Home"
I couldn't find it in any of the configuration settings.
Whilst I am here .. any tricks for getting iOS App Push notification working? Doesn't seem to fire on the iPhone at all
Uri
Sydney, Australia
5 answers to this question
  • 1 hour ago, RH_Dreambox said:
    Hi @UriT
    I myself have not tested if this helps you, but in configuration point 6 "General" you can change the Name of your HC3 to e.g. "My HC3".
    That is what I thought but unfortunately not, I have already renamed it there.
    I now saw that it is the same on the HC2, Fibaro uses the device's serial number as the sender.
    It's a bit silly when you have several gateway's because the serial number is hard to remember.
    HC3-0000xxxxx
    Message from FIBARO
    Uri
    Sydney, Australia
    Nope
    Any way to make feature requests to fibaro so that these things can be dealt with?
    Bugs me that it cannot be changed into something more user friendly.
