QuickApp - Philips Hue - All in One
QA for Philips Hue devices (for HC3 5.040 GA or above):
- support of philips hue lights, switches and sensors (motion, temperature, light) and some ikea lights connected to hue bridge
- unlimited number of hue bridges
- all logic and setup are centralized in QA HueMain
- creating of hue devices via click on buttons in HueMain
- a lot of parameters for advanced users
- automatic update of all devices in case of new versions
- centralized setting of favorite buttons,colors and icons (also possibility to override settings via local variables in every QAs)
- power consumption calculation for lights
- supported languages: en,cz,de,se,nl,sk,fr,ru,it,pl
/monthly_2020_08/image.thumb.png.89768d5ac25bcbe213f35ac9fe971499.png" />
Installation:
1.    Download HueMain.fqa
2.    Install HueMain.fqa to HC3
3.    In Variables in HueMain you have to setup:
- HueBridgeName1     - you can choose any name of your bridge - it can be whatever – allowed characters: a-z, A-Z, 0-9, _ - for example MyBridge1
- HueBridgeIP1    - IP address of your bridge for example 192.168.1.200
- Save variables - HueMain should start if everything is OK
4.    And than you have 2 options:
a)  you know your user in bridge - you can add it to Variables  - item HueUser1  ie.vPCj123VmJ18uWSHqpXfidxq5sjsP1q4Wi6DiCm
b) you can create user in HueMain - last part - button Create user (you will need physical access to your Hue bridge and press button there)
+ save/restart
5.    HueMain should run (if everything is OK) and show your hue devices in menu
6.    You can create QAs for group of lights, lights and sensors in menu in HueMain
Files:
1. QA - HueMain
2. Icons:
HOW TO CALL from other QAs or Scenes:
How to add icons where is not direct QA support for icon selection - for example for QA Hue Switches:
There is not possible to change icon for switch via user interface but you can do it via my QA:
1. you have to upload icons for hue switch:
  •  In HueMain - tab General - add Icon
  • Select your user icons and save it. You don't need to change icon for your HueMain
2. You need to get icon number - user icon has number with 4 digits (I hope that you don't have more 9999 icons currently :) )
  • right click on icon in your browser and select save picture - there will be - ie. User1007.png  - your icon number is 1007 (in some of icons ie. for lights you can see longer number ie. User1018100.png, always use only first 4 digits - 1018
3. In HueMain - tab Variables - add your icons number to IconSwZLLxxx (default icon is 0)  or IconSwZGPxxx based on your hue switch type - btw. you can set also default icons for all your hue devices
4. Save your variables and HueMain will be restarted and your HueQAs will have new nice icons :)
Edited by petrkl12
  • Like 12
  • Thanks 3
Link to post
  • Answers 86
  • Created
  • Last Reply
QA for Philips Hue devices (for HC3 5.040 GA or above): - support of philips hue lights, switches and sensors (motion, temperature, light) and some ikea lights connected to hue bridge - unlimit
New version of HueMain 3.00 is available (version of "child" hue QAs like lights, sensors etc. is 2.10).   What is new: - enabling/disabling of motion sensors - fix key id for frie
I can try to add button and method for disabling motion sensor   btw. my wife had similar problem with long shower without lights  so I had to add another hue motion sensor above shower and
Thanx for the very useful quick app.
I'm using the friends of hue switch.
The key id of the up right button is empty. So it wont work in scenes. Can you pleas fix that?
up right: Empty
up left : 2
down left : 3
down right id 4
Link to post
  • I don't have the friends of hue switch. I need to know what is returned if you press that button.
    /monthly_2021_01/image.png.c3d1d8e9d3c9adf85332d83b255ee0c9.png" />
    Link to post
  • On 12/22/2020 at 7:50 PM, jboileau173 said:
    A big and very big thank you for your work!
    This is really what I needed and I don't think I'm the only one.
    Do you think you can make the duration of the on and off transitions persistent?
    Thank you very much see you soon !
    It was already implemented - you can change variable "TransitionTime" in QA for hue lights
    Link to post
    Following  you find the printscreen when I push the upper left button:
    /monthly_2021_01/D6D0A81C-88A2-43AB-A1E7-B9B5516D97B1_4_5005_c.jpeg.4210c21ca55ff6e62cb492c931ecea0e.jpeg" />
    and now the upper right button no change! Nothing happens!
    D9AA4251-E9C8-4519-B1CB-178F30C9F47D_4_5005_c.jpeg.f1c142eccf78cab2d6454c7058cace94.jpeg
    Edited by fibaromac
    Link to post
    btw. my wife had similar problem with long shower without lights :) so I had to add another hue motion sensor above shower and persuade philips to add cooperative mode for two sensors :)
    Is there already a solution to disabling or enabling a motion sensor?
    When i'm away i like to turn on the outdoor motion sensor in the hue bridge.
    Link to post
    On 12/6/2020 at 8:53 PM, Goran111 said:
    This is great QA, thanks!
    But ... a basic question as I am new to Fibaro ... how do I install icons to this QA?
    Thanks!
    Good question how do you install all the icons?
    Link to post
  •  disabling or enabling a motion sensor is in development
    /monthly_2021_03/image.png.425c71b688187e1cb1e15f3972e15ee5.png" />
    Link to post
    What is new:
    - fix key id for friends of hue switch
    - added support for some other languages
    - a lot of other improvements
    In the first post there is also description how to call Hue QAs from other QAs or scenes.
    Edited by petrkl12
    • Like 3
    Link to post
    1 hour ago, petrkl12 said:
    New version of HueMain 3.00 is available.
    Awesome ! Thanks again for the great work !
    Is there any recommended way to update to this version ? Just set the "AutomaticUpdate" to Yes ? Will it keep the current child devices working ?
    Link to post
  • for complete update press this button
    /monthly_2021_03/image.png.b7f96d11b8ae92e981d64434cd016f0a.png" />
    All your Hue QAs will be updated too :)
    or you could wait till 3:00am if you have AutomaticUpdate=Yes in variables (btw this is default value)
    Link to post
    @mbnn
    @Goran111
    Link to post
    Thx! Great QuickApp better then adding the hue lights in HC3 if you ask me (i also like to use keep using the Hue app as well).
    Link to post
    got one question:
    rgbw/extended color light device exposes 'color' property when queried via /api/devices/xxx link
    but why doesn't color temperature light expose similat property? how can I get current light setting/temperature from such device?
    Link to post
    1 hour ago, naboo said:
    got one question:
    Philips Hue is using different method how to change color - 3 types but not R,G,B that is in Fibaro
    I'm changing this property in case of method 1 and 2
    For Color Temperature is not defined item for this type of QA device.
    Edited by petrkl12
    Link to post
    Is there any way to set color params using fibaro.call(QAID_HueMain, "HueCommands", ... command and to somehow be able to get/confirm the same color params by querying light device, e.g. using /api/devices/xxx ??
    I'm asking because when I call:
    fibaro.call(QAID_HueMain, "HueCommands", {type='Hue', action='colorRGB', deviceID=QAID_HueLight, colorR=254, colorG=0, colorB=0, value=0})
    and then query light device:
    /api/devices/434
    I'm getting:
    "color": "255,29,0,1"
    Yes, I know the last light param in fibaro.call command is not White channel so maybe would it be possible to add another call to QA to set light color by RGBW?
    Link to post
    /api/devices/434
    I'm getting:
    for colors you can use also native commands from philips
    and for color temperature
    Link to post
    but I won't be able to get the same params from light device in color property
    Link to post
