@MrPancake If you can adjust the gateway configuration so that IN5 can open the gateway in OPEN-STOP-CLOSE-STOP ... mode, you can use this input. Or do you want to use other features? You still have a free relay (out2) on the SI.   Please login or register to see this spoiler.
